Old 10-28-2010, 10:56 AM   #21
Year: 1983
Chassis: Carpenter
Engine: 8.3
Re: Hanging curtains
Ahh, well I am unsure what your looking at there. I have been considering wood stove. I remember a discussion on this forum about that I bet you have been involved in that one too. Good luck! Tell me do those special curtains make any difference?
seth
"grease buddy" and all around nice guy
madpsalmer is offline   Reply With Quote
Old 10-28-2010, 12:53 PM   #22
opus's Avatar
Chassis: All-American R/E
Dont know yet, cant hang them...lol. I will let you know.
Old 11-04-2010, 04:25 PM   #23
Scratchy's Avatar
Engine: 5.9 Cummings
I used suction cups with hooks. I picked a box of three up for $2.99 - each is supposed to hold 3 lbs. I found them in a craft store called 'Michaels' but I'm sure you can order them online too. I think they were intended to hang xmas reefs and such. Wet the back of them and they will stick to wherever. They won't scratch your inside paint and you can take them off when your are done. We sewed little loop holes on the back of our curtains to hang on the hooks. When I go down the road, I don't have to contend with storing rods, when I take the curtains down. Pluck the suction cups off or leave them - roll the curtains up and be gone.
They worked well for me. Something to think about at least.
Scratchy
Scratchy is offline   Reply With Quote
Old 12-06-2010, 04:58 AM   #24
mrblank's Avatar
Coachwork: GMC P3500
Engine: 6.2L
I have pieces of cloth and magnets right now, but I am going to be doing something I saw on another guys bus...
He used those clamps used to hold conduit to a wall, screwed them into the side of the wall and then used conduit as the curtain rod. It was the best idea I've ever seen, so I'll be doing it that way... I'll post pictures when I finally get around to doing it.
Not all who wander are lost... yeah yeah yeah, but those who are lost tend to need to wander! - Mux
mrblank is offline   Reply With Quote
Old 12-06-2010, 09:43 AM   #25
opus's Avatar
We went with the conduit thing for the bunk and bunk room and bedroom curtains. For the windows we "screwed" them to the wall. When we want them open, we roll them up. That way you get to have all your window glass area open.
Old 12-06-2010, 02:49 PM   #26
Engine: DTA360
Rated Cap: 16
Anyone source out the ones that hang from a track like the ones they use in the front of RVs???
dirtygoat is offline   Reply With Quote
Old 12-09-2010, 09:25 AM   #27
zim
zim's Avatar
Year: 82
Chassis: TransitLiner
Engine: Cummins 5.9l
I use nice cloth shower curtains to enclose the bunks. To hang them, I put an eye screw in each of the end walls, then pulled some heavy stranded wire between the two of them and tighten with a turnbuckle after threading the curtains onto the wire. Ping me if you want pics and I'll take some from the old bus.
Project Blog @ TechnoVardo.com
zim is offline   Reply With Quote
Old 12-09-2010, 10:30 PM   #28
mrblank's Avatar
Engine: 6.2L
yeah I'm working on the wood burning stove idea too! I think I can make something very small that will work, run the pipes out a window area, and have just a small enough wood stove to heat up this small bus when it gets freezing out, or when I can't plug a drop cord in somewhere. I've only been living in my bus for about 6ms now, and it's just starting to get too cold not to have some kind of heat, for now I have a plug, but not sure how long that will last since I'm boondocking at a ministorage place I rent to store the rest of my crap, lol.
Old 12-14-2010, 10:39 PM   #29
mrblank's Avatar
Engine: 6.2L
I finally figured out how I'm going to hang curtains!!! Velcro!!! They have some high strength grip velcro now, it should be pretty easy to use it (sticky back) to hang curtains... I'll let you know how it goes!
Old 01-01-2011, 10:58 PM   #30
mrblank's Avatar
Engine: 6.2L
So yeah Velcro works awesomely!!! The curtians haven't moved or fell down since I put them up that way.
Old 05-31-2020, 08:38 PM   #31
Engine: 444 7.3
Velcro was my plan as well as adding magnets due to weight of insulated panels. I have some thin reflectix that I am sandwiching between 2 layers of material to make adjustable blackout panels. Will be mounting my velcro in a complete strip above the window frames on both sides. Since I can't get a few windows to work I may not need as much.
G Unit is offline   Reply With Quote
Old 05-31-2020, 09:07 PM   #32
Sticky back velcro doesn't work too good. The velcro itself is far stronger than the sticky and pulls it off the surface. It is OK as long as you don't plan repeated attachments and removals. I'll add that the sticky is weakened by heat--like sun shine. I've found pop riveting the sticky back velcro helps but it looks sort of wonky.
I used sticky back velcro to secure part of the cover over the genny and frig on the tent trailer I tow behind my toad (when it isn't a toad) The warmth of the sunlight was enough to loosen the glue.
Who had hanging bunks Six Four Conversion General Discussions 3 11-20-2012 03:55 PM
windshield curtains gbstewart Conversion General Discussions 17 07-17-2012 09:17 PM
curtains ruthieb52 Everything Else | General Skoolie Discussions 9 05-29-2007 08:26 AM
Curtains for the bus!!! (Shades, really) Eric von Kleist Conversion General Discussions 0 08-10-2005 02:14 PM
