Old 07-14-2012, 07:26 AM   #1
Coachwork: Crown by Carpenter
Chassis: Ford B-800
Engine: 5.9L Cummins
Rated Cap: 55
Harsh winter prep for full-time RVing?
Hi,
I'm going to be living in Upstate NY quite a bit, often in the winter, and I'm curious how people in general go about making their skoolie livable in -5 degree weather (yes, negative 5).
We're pretty good at getting through the cold weather with added layered clothing, etc, but the interior needs some isolation still. What would be suitable for cold winters? Rigid foam panels? Rolls of fiberglass or cellulose? How thick would be enough?
And how do people typically heat their motorhome? Propane? Woodstove? I'm looking for the cheapest and most efficient. I think I would mostly find myself off in the woods instead of at an RV park, so wood heat wouldn't be impractical. But I would want to be prepared for heating/cooking when I don't have access to a bunch of wood, too.
I think what I'm ideally planning for is being able to be on-the-road and able to get up and go arbitrarily, so I don't think I can have too much left behind or set up outside (firewood, if any, would need to go onto the roof on a roofrack).
As per keeping the water/waste from freezing, I've seen people use foam panel skirting, but I'm not sure how practical this is, if I'm moving around every few days, in the -5 degree weather. Can the water/waste tanks be covered in fiberglass/etc insulation batts? Can the pipes be covered with insulation as well? Or is heat added underneath, such as via lightbulbs or wires wrapped around the pipes, etc?
tomas_maly is offline   Reply With Quote
Old 07-14-2012, 08:06 AM   #2
Re: Harsh winter prep for full-time RVing?
answered in your other post
Old 07-14-2012, 08:08 AM   #3
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
My opinion is on your other post.
Old 06-17-2016, 02:17 PM   #4
Engine: chevy
wheres the other post so i can get the information?
Shawna is offline   Reply With Quote
Old 06-17-2016, 05:34 PM   #5
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
As one who grew up in Illinois in the mid to late 70's & we had wind chill -30 to -60 deg below zero your best bet is do what I did,,, Move to California.
Old 06-17-2016, 06:51 PM   #6
I just plan to alwasys drive SOUTH in the winter and I'll have all SIX heaters on HIGH!! while I drive
full time in new england? jndonnelly On the Road | Travel, Trips, Camp Sites, Tailgates 0 10-11-2010 11:49 AM
Full-timing it three months at a time josetann On the Road | Travel, Trips, Camp Sites, Tailgates 1 03-06-2009 03:04 PM
Anyone here actually *live* full-time in a bus? Griff Everything Else | General Skoolie Discussions 4 08-05-2007 11:19 PM
SOS BUS - Full time bus w/ raised (new) roof bradnjosie Skoolie Conversion Projects 2 10-26-2005 10:04 AM
I want to go full-time, need advice/suggestions! Ryan Grimm Everything Else | General Skoolie Discussions 0 09-19-2005 09:21 AM
