Old 07-14-2006, 01:56 AM   #1
davido's Avatar
Has anyone done their own slide out panels/sides?
I tried searching but couldn't find anything. Maybe I'm not using the right terminology? I did see this though:
http://www.skoolie.net:16080/gallery/v/ ... 1.jpg.html
Just wondering how it's done and how hard it is. Thanks.
davido is offline   Reply With Quote
Old 08-21-2006, 10:48 AM   #2
You might try a slide-out from a wrecked RV or trailer....just be aware you may need hydraulics to actuate it, and they are notorious for leaks and hoses exploding. Lessee, hydraulic pump, hoses, tank, expensive fluid, electrical system....
And a tendency to slide out while driving on the highway, according to some horror stories I've heard....RV catalogs sell rods meant to hold the slideouts CLOSED while driving, so the stories must be true.
And being RV components, they are probably made VERY light-weight, so I'd question their durability and strength.
You would also need to reinforce the bus where the cut-out is, to provide stiffness and strength that you are removing when you cut the wall out.
I've seen a couple major motor coach mods on-line (can't remember where, obviously) that used welded steel frames, actuated with rack-and-pinion setups driven by electic motors and gear reducers. Nice thing about this is they used a manual crank to retract the slideout, it engaged the reduction gear motor shaft through a hole in the floor. Took a HELL of a lot of cranking, but what the heck, if it worked for a B-17 main gear, it'll work for you....
RV catalogs also sell SUPPORTS to put under the slideouts when parked and extended, seems the frames tend to sag after a while.....
Caveat Emptor.
Ryan Grimm is offline   Reply With Quote
Old 08-23-2006, 10:45 PM   #3
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
All trailer's that have slide out's (which is almost all new ones) use electric motor's to slide in and out. I talked to a few of the tech's at the rv dealership I worked at and non had ever actually seen a slide move out while in motion. Just my 2 cents. -Richard
captainkf is offline   Reply With Quote
Slide Outs Zen Ken Conversion General Discussions 30 11-13-2019 02:53 AM
slide out thesaltydog24 Conversion General Discussions 4 02-18-2018 03:35 PM
Cutting the roof & skinning the sides lornaschinske Conversion General Discussions 2 04-01-2011 10:55 AM
Solar Paneled Sides greatidea Electrical, Charging and Solar 13 10-14-2010 06:42 PM
slide out on ebay. captainkf Everything Else | General Skoolie Discussions 0 01-05-2007 09:12 PM
