Old 07-20-2019, 02:03 PM   #101
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
i have alot of experience to share with rockwool if any one wants to know the insulation value verses others and the fire resistive values.
to keep it short ask if you want to pursue this road.
Old 07-20-2019, 02:09 PM   #102
I'm very interested to hear what you know. I haven't made any insulation decisions yet and I'm curious about rockwool. I'm planning on 3" of insulation most of the way around, so rockwool would work for that thickness.
Old 07-20-2019, 02:10 PM   #103
HazMatt's Avatar
Chassis: IH 3800, 8 window
If you say so.
Medium thickness steel wool will catch fire with an ordinary match.
Just sayin'...
Old 07-20-2019, 02:59 PM   #104
Originally Posted by HazMatt View Post
If you say so.
Just sayin'...
With that info I have several woodstoves that I knitted going very reasonably
Old 07-20-2019, 03:02 PM   #105
The video clearly shows them hitting it with a torch and it doesn't ignite or burn, and is cool to the touch on the other side of 2". I use that Rockwool in my powder ovens and have nothing bad to say about it, other than it is a bit pricier than other insulations.
Old 07-20-2019, 03:13 PM   #106
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
If you say so.
Just sayin'...
and how does that relates to lava ?
Old 07-20-2019, 05:38 PM   #107
HazMatt's Avatar
Indirect vs direct flame. Not to mention compaction percentage.
Otherwise, I'm afraid I'd have to inspect your needlework.
Originally Posted by BlackJohn View Post
With that info I have several woodstoves that I knitted going very reasonably[emoji2]
ummm...
"Lava's a many-splendoured thing"..?
Old 07-20-2019, 11:06 PM   #108
Easily ignited, prolly.
No, not actually flammable man.
Old 09-03-2019, 06:51 PM   #109
For those of you who have insulated between the roof ribs with rigid foam, and subsequently added through-roof features down the road (more vents, skylights, holes for solar power cables, etc.), you are likely to have decent insight on it's mechanical performance.
1) Have you noticed any issues with the foam staying put?
2) How much time and miles had passed since initial install?
3)What adhesives or methods did you use to keep the foam from shifting or settling?
4) Did you fill the cavities entirely, or provide a gap for a radiant barrier?
5) What would you do differently, given the knowledge you have about the products and methods you chose, a similar time frame to install, and 150% of the budget you spent?
6)Would rockwool solve any of your problems?
KalamariSafari is offline   Reply With Quote
Old 09-03-2019, 06:57 PM   #110
Chassis: Front Engine
I used rock wool panels, roxul I think, 1.5”. It’s been a couple of years but very few miles and it’s still perfect. I cut holes for the toilet vent recently to m go through the roof instead of the wall (big improvement!) and for solar penetrations. I would use the stuff again for sure. It’s less toxic than regular foam board if it burns and supposedly is mold resistant. I’ve has a leak or two and haven’t had any mold so it’s been great so far. No glue, no nothing, just wedged them in to fit and put the cedar ceiling up.
Only thing I would do differently would be additional supports for the cedar ceiling because I was dumb and skipped a rib or two and it was just dumb.
rffffffff is offline   Reply With Quote
Old 06-14-2022, 07:47 PM   #111
Year: 2006
Coachwork: IC
Chassis: CE200
Rated Cap: 66C 44A
Tell me everything! We just bought our first bus and are overwhelmed with information on insulation. We were leaning towards polyiso and it's high R-value, we will be in Texas most of the year. But someone mentioned rock wool and it's sound dampening properties so my interest is piqued. Thank you!
Beansprout is offline   Reply With Quote
Old 06-14-2022, 08:17 PM   #112
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Welcome. Let's see it.
Welcome to skoolie.net.
Many conversions applications depend on the type of bus you have, van, shuttle, full size, or coach.
Please, complete your user profile, so members who have experience with that style can answer, with a solution that fits your specific rig.
Click [User CP]
then [Edit Details]
- there you can enter relevant data about your bus.
You might fill out the Registry while your there & upload some pics so we can see your skoolie.
