Has anyone repaired salvaged components??
Ok...a buddy gave me some salvaged RV components: Stove, heaters, and water heater.
Magic Chef 4 burner stove/oven combination unit. Doesn't look in too bad of shape. Needs a thorough cleaning and it looks like it should work, but I can't find the serial or model number on it - where should I look? It's no where on the outside that I can see, nor in the oven. I'd like to try to find a repair manual on this - ideas? Parts supplier for older ovens?
Does anyone have a source for a repair manual or anything on the following salvaged space heaters:
Suburban Heater
Mdl# NT34S
Code: LAET
Input BTU: 34,000
Output BTU: 27,000
Ser#: 2-1408486
Note: Looks to be in very good condition. Need some info on how to safety check it and install it. I'm thinking of installing it under the bus and ducting the heat up through the floor. Has anyone done this?
Suburban Heater
Mdl# NT16SF
Code: LAFT
Input BTU: 16,000
Output BTU: 12,000
Ser#: 1407213
Note: Not too bad of condition. Looks like it ducts heat out the face plate so this would have to be installed inside the bus somewhere. Not sure if I need this one with the other larger unit. Thoughts?
Water heater Mobile Temp Inc.
Mdl#: G601
Cap: 5.7 gal
Ser#: 131408
Note: Can't find any info about this manufacture. It's likely going on the scrap heap as it looks pretty rough and I'd like to install is an inline flash heater that gives continuous hot water without a tank. Has anyone installed one of these? Thoughts, ideas?
ANY good sources for RV repair and maintenance manuals would be nice.
THANKS
