Old 10-22-2019, 01:18 PM   #1
Hat Channel Measurements
Heading out now to pick up the hat channel for an International. Still need measurements on hat channel for Thomas and BB. Anyone?
Old 10-23-2019, 12:25 AM   #2
Chassis: TC1000 FE
Engine: 5.9
How exactly do I measure the channel? I should be done with most of the demolition by this weekend.
lebusmagique is offline   Reply With Quote
Old 10-23-2019, 01:24 AM   #3
Measurements can be done after removing a pair of windows.
Thickness of metal
Total width of wings (hat brim)
width of channel
depth of channel
Old 10-23-2019, 06:17 AM   #4
Try square tubing for a BB. May save you a ton of money and time if you find some that fits. Wes aka MuddaEarth did.
Roll Your Own Build Thread
Old 10-23-2019, 09:35 AM   #5
Thank you.
I was trying to remember who's build thread it was.
I tried to buy square tube for my Bluebird. Local metal supplier insisted that there is no such thing as 1-3/8" square tube.....
Old 10-23-2019, 01:24 PM   #6
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
Thank you.
I don't know about 1 3/8" square I used 1 1/4 tubing on my BB and it fit perfectly. Gene
Gdog 5651 is offline   Reply With Quote
Old 10-23-2019, 02:42 PM   #7
Mine is definitely 1-3/8".
When I couldn't find 1-3/8" I bought 1" square tube and 3/8"x1" flat stock and welded the flat to the square. It fit perfectly but took forever to do. Scrapped that plan and had c channel bent up.
Old 10-24-2019, 11:11 AM   #8
Chassis: TC1000 FE
Engine: 5.9
Do I also have to cut off a piece so I can get those interior measurements?
Old 10-24-2019, 12:54 PM   #9
You shouldn't, after removing the 2 windows the complete rib is exposed.
Old 10-26-2019, 01:56 PM   #10
To be safe, I did take a sample to the fabricator. They came out perfect.
Old 10-26-2019, 02:25 PM   #11
Same here.
