Old 08-18-2008, 02:17 PM   #1
Headroom
I am shopping for a bus to convert for RVing. I would like to have an interior height of 6'-1" or more and I would prefer not to do a roof raise. Are there certain Year/body/chasis (YBC) combinations that I should be looking for to get maximum head room. Perhaps some of you could post your YBC and headroom.
Thanks
Carl
carlsauction is offline   Reply With Quote
Old 08-18-2008, 08:58 PM   #2
GoneCamping's Avatar
Re: Headroom
To be realistic, most year/body/chassis has more than one height available. Best way to describe this is a visual on the roof line just behind the drivers area. If you look at the profile of a bus (side view) roof line, and the roof drops about 3" a foot so behind the drivers seat, the interior height will be approx 6' high. If the roof goes straight then it should measure about 6'3" inside, and if the roof raises up some then you are looking at about 6'6" interior height.
These are generalizations here, exact measurements may vary some from one make to the next, but you'll find that to be close. I wanted to find a raised roof (6'6") for my Thomas Safety Liner, but locally the only thing they had was the drop roof at the time. Same bus, same chassis, same everything except the roof line is different.
Next time you are out and riding around (school is starting now anyway) look at the various buses and their roof lines and you'll see what I'm talking about...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 08-18-2008, 09:08 PM   #3
Re: Headroom
For an example of the raised roof look at this image here, right behind the drivers window you can see the roof line go up (this is a Thomas Safety Liner BTW)....
This next picture is the one I bought, you can see the roof line drops behind the door area...
*Cliff*
Short-bus question about headroom Diesel Dan Short-Bus Conversion Projects 5 04-10-2009 09:02 AM
Which models have the best headroom? Diesel Dan Conversion General Discussions 3 04-08-2009 11:31 PM
Max Headroom SeanF Everything Else | General Skoolie Discussions 4 11-16-2004 12:27 AM
