Old 11-11-2012, 09:01 PM   #1
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
heated mirror controler
does this look like the heated mirror controller?
proconsul100 is offline   Reply With Quote
Old 11-12-2012, 12:52 AM   #2
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: heated mirror controler
Looks like a Bosch relay to me. Have you traced the wires? Put a test light on it before and after you turn on the heated mirrors and see if it lights up.
I'm hungry!
You Gotta Let Me Fly
Old 12-02-2012, 12:42 PM   #3
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Seems like a lot of amps to me.... 75 amps... what ever it is its pulling some juice.
Old 12-02-2012, 04:58 PM   #4
Its just a relay which would supply "high amp power" to something...what ever it was suppling "wanted" more amps than the wire would carry....that's why its been over heated (from picture)
I have retro fitted several power mirros and heated mirrors over the years.
Using relays saves wire size etc. From the high amps needed from the "device"
Say your mirros had a 120 watt eleent you need to "switch" 10 amps no worries if switch was good for 20 amps(safe side of needs)
If the mirrors had a larger draw the incoming wire would need to be bigger to supply the amps needed...which could burn up or melt a switch,
So you use a 40 amp relay to supply 40 amps to the source(mirrors) you could "activate" said relay with a couple amps (actually less than 1 amp)
And it would turn relay on...at that point power would come and go thru the relay up to 40 amps if wires in/out of relay could handle it
...a hate a phone for editing crap....I will give more info if needed 2morrow on a real computer
Old 12-02-2012, 05:23 PM   #5
Moderator
crazycal's Avatar
I don't think the wires are burnt.
I'm hungry!
Wanted Passenger outside mirror for a cut-a-way 91 Bus Guy Classifieds | Buy, Sell, Swap 3 07-30-2013 08:54 AM
big rear view bus mirror proconsul100 Conversion General Discussions 5 11-05-2012 02:22 PM
Radiant heated floors. jjhomeonewheels Conversion General Discussions 4 07-30-2011 06:37 PM
Flex Watt heat tape..... Heated floors / tanks cheap & e KC10Chief Conversion General Discussions 0 12-30-2006 02:45 PM
Mirror Window Tinting Steve Conversion General Discussions 5 02-05-2004 06:57 AM
