Old 09-24-2018, 10:27 AM   #1
Chassis: Amtran
heated mirror fuses?
Good morning everyone,
I have a 2001 International, Amtran and I need to know if anyone can tell me what size fuse is running the heated mirrors, the stairwell heater fan and the two large fans above the front windshield. I removed a lot of wiring when I did my conversion and I need to hook these items up but needless to say didn't write down or keep tract of what size they were. Does anyone have a similar bus or even these items on their bus and can give me a general idea of what they might be?
Thanks,
Michael Callahan
Cdimples67 is offline   Reply With Quote
Old 09-24-2018, 04:21 PM   #2
Thanks,
Michael Callahan
most all of the equipment wiring in our school busses is running on 20 amp breakers in the panel... Amtran often has a label on the inside of the electrical panel door that shows what position each accessory was in... they are most often all breakers.. both my 91 and my 00 bus use all 20 amp circuit breakers and the devices plug into the breakers...
Old 09-25-2018, 03:52 PM   #3
Chassis: Amtran
Hi Christopher,
I installed a backup camera yesterday and the fuse block I left in has 7.5amp fuses and 1 10 amp? I haven't seen any breakers in my bus unless they are calling fuses breakers? I did look at the sheet on the door to the fuse panel and located the heated mirrors but started going cross eyed after 5 mins so I will try again today.
Thanks for your reply I will post my findings after I rewire everything.
Michael Callahan
fuses, heated mirrors, stairwell heater, windshield fans, wiring problems
