Old 08-12-2007, 08:57 PM   #1
Engine: 7.3 diesel
Re: Heater Plumbing
You may be able to hose a piece of 3/4 inch hose to cover the pipe on the heater core and slide the 1 inch hose over it, maybe. I also believe they sell adapter hoses that do it this way I remember seeing them once before when I was doing this on o bus. Another option is to go to your hardware store and find some brass fittings that will make the adapter you need.
Old 08-13-2007, 06:29 PM   #2
Coma's Avatar
Year: 1981
Engine: 345
Rated Cap: 69
Re: Heater Plumbing
Brass fittings will handle your needs.
Here you can find whatever you need.
http://www.ppe.com/pdf07/0263-0265.pdf
If not on that page, go to the main index page http://www.ppe.com
Coma is offline   Reply With Quote
Old 08-14-2007, 10:21 AM   #3
Coma's Avatar
Year: 1981
Engine: 345
Rated Cap: 69
Re: Heater Plumbing
Nothing is required or suggested on the barb side. Just a good clamp. What you are experiencing is a result of old age.
DIY Heater for a Small Space: pulse jet heater lornaschinske Everything Else | General Skoolie Discussions 8 07-15-2012 09:54 PM
a few plumbing questions lornaschinske Conversion General Discussions 2 12-27-2010 05:28 PM
Mr. Heater propane heater glock17 Conversion General Discussions 15 10-21-2007 09:59 AM
plumbing question deadhead Plumbing, Water and Waste 13 04-18-2007 04:09 PM
Bus floors/plumbing wmah Conversion General Discussions 0 08-14-2006 07:15 PM
