Old 03-11-2017, 02:01 AM   #1
Chassis: Bluebird
Engine: 5.9L cummins
Rated Cap: 84pax
Heater removal
I have a 93 bb re I removed the heaters today but how can I keep the front heater in for defrost would I need to run a hose from the engine to the blower unit in the dash and back? Does this make sence?
Illusion is offline   Reply With Quote
Old 03-11-2017, 05:56 AM   #2
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
yes they need to run to the front, i was going to try and hide mine under the bus but changed my mind. try and hide one of them rear heaters in your build if you can, cant have too much heat when you need it.
my build pics
Old 03-11-2017, 06:12 AM   #3
jctrembly's Avatar
Chassis: Sold
Yes, keep your rear heater, I had to buy one for my RE. It was a Florida bus and only had a front heater. I do not plan to drive in the winter, but when it's 50 out that's still cold. You don't want to burn extra fuel for heat when you got all you need from that engine.
Sent from my Nexus 5X using Tapatalk
jctrembly is offline   Reply With Quote
