Old 01-10-2018, 08:16 PM   #41
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
I my vintage motor home I heat heat water and cook on propane intend to do so with the Bus in progress I heat the crib with propane buy in advance this year 1.90 gal in the house tank or if I drive to the dist price is the same and I intend to so in the future Although I will prob install small wood burner it will be for the Boss as she likes live fires
Gdog 5651 is offline   Reply With Quote
Old 01-11-2018, 10:45 AM   #42
I have an option. It may be a bit expensive but it will kill two birds with one stone. A marine diesel heating stove. It heats and also has the ability to cook on it like a regular propane stove. It can also run on kerosene in a pinch. They use hot water coil for heat, it could be a forced air set to run through the bus heaters, or just heating straight off the stove.
Dickson Marine seems to be the best in quality and praised by my boaty acquaintances. They can be found used at boat supply places and on ebay.
http://dickinsonmarine.com/product_cat/diesel-stoves/
ben2go is offline   Reply With Quote
