Old 01-09-2004, 10:41 PM   #1
andybus9's Avatar
Heaters How can i be safe when using propane powered heaters
Ok I live in minnesota. I want to work on the interior of my bus during this winter season but not frezze my feet off. My freind has a Torpedo heater and i know that they can start fires very easy. What i want to do is open the back door of the bus and setit on a stand outside of the bus about a foot or two from the back door enterance and let if blow in the heat to try and relive some of the cold. The bus holds the heat well with the dual vapor barrier and 1/4 inch ply wood panels below the window line to the seat rail. It does stay warm with just the bus heat and the doors closed for about 8 hours. BUt i want to be able to work and not have to run the bus at 1200 rpms to heat the engine to heat the bus when sitting there. Any ideas?
Andy B Bus#9
Minnesota
KC0JCK
andybus9 is offline   Reply With Quote
Old 01-12-2004, 12:01 PM   #2
Les Lampman's Avatar
Andy,
Other than protecting things from the high heat coming out the end of the blaster the biggy is ventilation, which it looks like you'll have plenty of; those things are not intended for use in enclosed spaces.
If I had my druthers, I'd use an electric space heater or two. This assumes, of course, that you can get power to the bus (use a good heavy duty outdoor power cord). That way you can leave the doors closed and not worry about permanently going to sleep.
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Help me take my heaters out. jjhomeonewheels Conversion Tutorials and How-to's 7 08-27-2017 09:13 PM
heaters?? gbstewart Conversion General Discussions 0 05-19-2010 05:01 PM
Propane heaters for school buses (article) TygerCub Conversion General Discussions 3 08-23-2009 12:52 AM
skoolie heaters majjecc Conversion General Discussions 4 02-19-2006 09:19 AM
Propane Water Heaters ~ Advice Needed pixie Conversion General Discussions 5 08-21-2004 10:53 PM
