07-19-2016, 05:38 PM
HELP! Hole in floor! Need answer ASAP.
Hey guys so I'm just about to put in my flooring tomorrow and there's a hole in the front right side of the bus above the diesel tank that had a metal panel on it originally.
My question and concern is: Will I ever need access to this hole for any reason? Should I cut a hole through my insulation, subfloor etc. to have access to it? Or can I just seal it off and not worry about it?
Here is a picture of what I mean
Any info on this would greatly help, as my time to work on this is limited to the next couple of days.
Thanks!
07-19-2016, 06:18 PM
Chassis: Genesis
You will want access to it. That is how you replace a fuel sender and such.
Does the hole provide access to anything important; fuel pump/filter, hanging hardware, etc?
07-19-2016, 06:57 PM
Chassis: International 3800 chassis
Engine: T444e
Ok I have same issue with one big question
Is that how I get my dash fuel gauge to read correctly
I thought was gauge but not looking like my problem
Cheryl Ann
Blessed to be Alive!
07-19-2016, 07:02 PM
What is the problem with it now? Is it at least consistent in the way it reads?
07-19-2016, 07:05 PM
This is what's inside.
07-19-2016, 07:20 PM
Looks like a float/sending unit to me. If you ever need to replace it, to get your gas gauge working again, you'll want access to it.
07-19-2016, 07:28 PM
Hi,
I have a gas motor but also have a plate access in the floor to the sending unit (also known as the gas gauge fuel level sensor, by me because sending unit always trips me up for some odd reason) it is called a sending unit because it "sends" the gas level information (measured in resistance) to the gas gauge.
Goodness can you imagine having to drop the gas tank to replace one? yikes!
07-19-2016, 08:44 PM
IF YOU DECIDE TO COVER IT....
Lay down a tape measure and document the outer edges with digital camera... Or phone
Distance from wall, size of circle... Etc.
Digital film is cheap!
07-19-2016, 08:54 PM
Engine: T444e
It only reads 1/2 when is actually full
Cheryl Ann
07-19-2016, 08:56 PM
Engine: T444e
07-19-2016, 09:15 PM
Double post
07-19-2016, 09:42 PM
Sounds like a new float/sending unit is needed.
07-19-2016, 10:35 PM
Engine: T444e
Well I guess that I'll need to get greasy then cause that thing is nasty
And find that part
07-20-2016, 07:18 AM
Diesel fuel is pure Hell on sending units.. thus why the hole above it in the bus floor... you may get many many years out of yours but you may also only get a few.. quality of fuel and additives (northern areas of the country) play a big part in how long that sender lasts...
ive seen a lot of people locate a cabinet above it in their bus and simply cut out the cabinet and make a new piece for their cabinet bottom to place there... or as others mentioned you can mark it and make sure its something easy to remove.. school bus gas tanls are in safety cages that are very much a pain to remove to drop the tank..
07-20-2016, 11:17 AM
Coachwork: Crown / Pusher
Looks to me it's to access the fuel level sensor only, so if it was mine I would cover it & if you ever have a problem with it just drop the tank, it really isn't that hard & I've dropped quite a few fuel tanks & even did the one on my bus with about 60 gal of fuel in it, best way is use a transmission jack with a piece of 3/4 plywood on the jack cut down to what ever size you need to keep it stable.
07-20-2016, 11:20 AM
And find that part
I'm using a fuel tank for my grey tank & this is the new sender I'm using, direct bolt in also.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
07-20-2016, 11:33 AM
Chassis: B3800 Short bus
Oh boy.... Have you dropped a school bus tank yet? I have. It's not fun. The tank is usually protected by a cage made out of 3/16" walled 2"x3" steel tube. The cage alone must way close to 200lbs. I'd keep that hatch somewhat accessible. Even if it's inside a cabinet that makes it difficult to reach it'll still be a smaller job than dropping the tank if you need to muck around with the sender.
In regards to the fuel gauge not working, mine was in the same boat. It would always read somewhere around 1/4 tank. The problem ended up being that the wires were corroded. The sender worked fine. I ran new wire, cleaned the contacts on the sender and it's been reliably reporting the tank level since!
Good luck!
EDIT: Oh, and I should add that all that work was easily accomplished by climbing under the bus to run the wire then making the connections through that access hatch. A year after that fix I did end up dropping the tank to paint it, relocate it and mount it with lighter brackets. I made a new access hatch to reach the sender in it's new location.
07-20-2016, 11:44 AM
Good luck!
Mine didn't have a cage but it's made from some VERY thick steel, I personally have not seen any Crown with a cage & yes I did remove mine & relocated it about 30in rearward so I could mount another 112 gal tank for my greywater.
07-20-2016, 01:07 PM
Thanks everyone for all the opinions and information!
