Old 04-03-2010, 09:35 PM   #1
cheezypsnookle's Avatar
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
HELP i am unsure the purpose of these?
i think its a electrical pug but idk what for???
and then these knobs are a mystery to me
this is the left one
this is the right most one
if you know i would like to hear what these are.....
cheezypsnookle is offline   Reply With Quote
Old 04-03-2010, 10:08 PM   #2
busdriver_phil's Avatar
Coachwork: AmTran RE
Re: HELP i am unsure the purpose of these?
The plug is for an engine block heater, helps warm up the coolant for easier starting and faster heat in cold weather.
I'm not positive about the knobs, but I believe the one on the left is a fresh air vent under the dash, and the right would be a temperature control (coolant valve) for the defrosters.
The conversion of Miss Euphegenia, a 1999 AmTran RE: http://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Old 04-03-2010, 10:13 PM   #3
Engine: cummins 5.9
thanks i i would have never thought of an engine heater.....
and i have turned the knobs a little but didnt feel air but now that i know they arnt the" break the bus knobs" i will turn the **** out of them.....
Old 04-05-2010, 09:54 AM   #4
recycler's Avatar
Year: 86
Coachwork: Thomas saf-t-liner
Rated Cap: 40
You gott to love the bewilderment one can experience when discovering random knobs and valves that come across as mysterious at first then make total sense (usually!) later!
recycler is offline   Reply With Quote
Old 04-05-2010, 05:10 PM   #5
Coachwork: Ward Genesis
Engine: DT466/MT643
Or finding half a dozen unlabeled switches!
Jarlaxle
Old 04-05-2010, 08:55 PM   #6
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
i thought the left one was for the flame thrower
Old 04-07-2010, 08:44 AM   #7
dentedvw's Avatar
Coachwork: Thomas SafTLiner
Chassis: FE
Rated Cap: 60
If you are asking about the throttle knob, got me. Mine doesn't budge at all, in any way, no how. I was hoping I could use it as a cruise control, but even I know better.
dentedvw is offline   Reply With Quote
Old 04-07-2010, 01:32 PM   #8
Engine: cummins 5.9
yeah our throttle knob is stuck also i tried cc with it to no avail
Old 04-07-2010, 03:41 PM   #9
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
On some of them you need to turn them counterclockwise to loosen them so that you can pull/push the cable. Then a quick twist clockwise locks it in whatever position you set it at. That's how mine is set up.
Old 04-08-2010, 05:19 PM   #10
browncrown's Avatar
Rated Cap: 79 at Birth
Mine works like jkindt said. They are good to hold the idle a little faster for faster warm up while you are doing other things to get ready, or just pull the thing all the way out while on the road and use it as "Okie Cruise Control" Not trying to be offensive to any Okies, I are one too!!! and proud of it
BC
what is purpose of top yellow lights? bansil Everything Else | General Skoolie Discussions 9 05-29-2012 08:15 PM
Purpose of Rub Rails? syke Conversion General Discussions 8 04-22-2012 10:40 AM
Best all-purpose batteries? josetann Electrical, Charging and Solar 13 07-18-2009 09:52 PM
Does anyone tow a motorcycle / scooter / dual purpose? TygerCub Conversion General Discussions 10 05-13-2009 08:51 AM
Unsure where to post U-Haul Everything Else | General Skoolie Discussions 6 06-15-2007 12:50 PM
