Old 04-18-2018, 10:54 AM   #1
Chassis: 3800 Carpenter
Engine: DT360 / AT545
Rated Cap: 65 passenger
Help Identifying This
Anybody know what this is? Doesn't seem to be connected to anything. Do I remove, refurbish or re-purpose?
Thanks
oredigger is offline   Reply With Quote
Old 04-18-2018, 12:31 PM   #2
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Thanks
Looks like an air dryer. Keeps water out of the air brakes
Dead pirate is offline   Reply With Quote
Old 04-18-2018, 04:39 PM   #3
Rivetboy's Avatar
Thanks
You start learning about your brake system pronto and see if that air drier was replaced with another.Excessive amounts of moisture in an air brake system is bad.
Rivetboy is offline   Reply With Quote
Old 04-18-2018, 04:43 PM   #4
brokedown's Avatar
For real!
https://www.instagram.com/p/BeiklJUH...nderlounge_bus
Old 04-19-2018, 05:31 AM   #5
Thanks guys. Good point about draining the tanks. Here's a pic of my air dryer. I guess it was replaced at some point and the old one left there. I'll get rid of it. It seems to be leaking oil too.
Old 04-19-2018, 08:46 AM   #6
Year: 90
Chassis: international
Not an air drier. Looks to be part of a hydraulic system or accessory. If it,s not hooked to anything just remove it. Seems to be a lot of rust under there.
Old 04-20-2018, 09:32 AM   #7
Rivetboy's Avatar
I went back and looked harder maybe it was a reservoir for?? Kind of hard to tell.
