Old 01-02-2018, 03:09 PM   #1
Help: Rivet - Factory Blind Rivet
I need the actual rivet that the busses came from the factory with. I need to redo some areas and want to use the structural stuff. Does anyone have the part number or what they are called. I thought they were Monel but couldn't find Monel for steel application.
Thanks
Sent from my SM-G955U using Tapatalk
Serengeti is offline   Reply With Quote
Old 01-02-2018, 03:32 PM   #2
Jdawgsfanasty's Avatar
Thanks
Contact the manufacturer...
Jdawgsfanasty is offline   Reply With Quote
Old 01-02-2018, 03:36 PM   #3
Lol....yeah....they are about as helpful as a boat anchor
Old 01-02-2018, 03:36 PM   #4
The manufacturer of your bus SHOULD be able to give you the rivet info.
Roll Your Own Build Thread
Old 01-02-2018, 03:51 PM   #5
Is it a Thomas? Here's a local dealer's number...ask for parts...713-580-8600
Old 01-02-2018, 03:57 PM   #6
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I used these bad-boys. Very happy w/ quality.
Huck Magna Bulb
Old 01-02-2018, 05:32 PM   #7
Huck Magna Bulb
Thanks. You wouldn't happen to have a picture of your installation? Just curious to see the finished work.
Old 01-02-2018, 06:08 PM   #8
Update: Found the correct stuff on www.boltdepot.com. What you want is an Interlock(structural) Dome head rivet, Zinc plated steel mandrel
Old 01-02-2018, 06:23 PM   #9
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Don't know that they actually used the zinc plated? The plating actually crushes as the rivet is pressed and still leaves you with black steel that the rivet it made of originally.
Not saying it won't work but paint isn't going to stay on the galvanized for very long.
Wipe it with vinegar and you can get 5-6 years(guestimation) without it 1 but that's about the same as a true steel rivet without a good primer and coat of paint.
Just an opinion?
Good luck
Old 01-02-2018, 06:53 PM   #10
Just an opinion?
Good luck
I am going to scuff the area with a scotch brite pad anyway, so primer should stick well
