Old 11-10-2019, 08:49 PM   #1
Help: Rubber flooring removal Ford e450 shuttle bus
Hello,
I was able to remove the seats in my Ford E450 shuttle bus. I am now working on removing the rubber flooring. Does anybody know how to remove the nut in the picture. Tried unscrewing from the bottom but the nut and bolt both rotate, nothing on the top moves.
Smitha
Smitha is offline   Reply With Quote
Old 11-10-2019, 09:05 PM   #2
Chassis: IH 3800
Is that center circle some form of cap? Have you tried prying it out?
-NotSoGrand Garage-
https://www.youtube.com/channel/UCjw...WCpE8n6fLiplJA
Old 11-10-2019, 09:48 PM   #3
Originally Posted by Smitha View Post
Hello,
Smitha
Not sure exactly how the floor of a shuttle bus works, but I think you're also just rubber glued on top of plywood. Getting that rubber off will be a pain and there's no need for it. Set a circular saw with a demo blade to slightly less than the bottom of the plywood and cut the floor into small chunks (I did 1 foot square but other have done larger) then just pry the chunks out.
Old 11-11-2019, 12:50 AM   #4
Bon Voyage's Avatar
Rated Cap: 81
Can you pry one of those middle circles out?
Bon Voyage is offline   Reply With Quote
Old 04-12-2021, 10:53 PM   #5
Chassis: E-450
Engine: 7.3 liter Ford Power stroke
Rated Cap: 25
You may need to just take an angle grinder to it.
ppmuetze is offline   Reply With Quote
Old 04-12-2021, 11:48 PM   #6
DAVEHOLMAN's Avatar
Coachwork: Thomas Saf-T-Liner
Chassis: HDX with lift
Engine: Mercedes MBE 920
Rated Cap: 22
Angle grinder is my go to answer for almost everything. lol
DAVEHOLMAN is offline   Reply With Quote
Old 04-13-2021, 12:42 AM   #7
If its in good shape, just leave it in. helps with sound deadening road noise.
Move on to the next item.
