Old 04-30-2009, 06:45 PM   #1
Coachwork: Richmond
Rated Cap: 69
Help! What kind of batteries do I need for my bus?
Hello,
I am the proud owner of a '91 International with a DT466 engine. I purchased the bus recently post interior conversion and my friend converted it to run off of SVO. Sadly, like a fool, I did not disconnect my batteries before letting the bus sit for a long time in storage. Now as spring time blossoms, I find myself unable to start my bus because it appears the batteries are dead.
The bus came with two batteries which I believe are wired in parallel. The first battery was unlabeled (does not list CCA) but was relatively small, it looks like your standard old truck starter battery. The second battery is an extremely large battery (looks like an 8D in size). Again, the labeling is not very informative. However, it does rate the cold cranking amps at 1150.
I purchased a marine/deep cycle automatic charger, pulled the batteries, and let them charge up till the charger indicated green. The small battery will not hold a charge, at most my battery tester reads weak at worst it reads bad. My charger spent a large time in 'desulfation cycle' for this smaller battery. The 8D battery at best reads good but quickly discharged (while not connected) to weak and may further discharge till the tester reads bad (waiting to see).
I am looking to replace these batteries this weekend with some group 31 and/or 8D replacements. However, I have no idea how to determine how many CCA I need to get the International started. Should I use 2 group 31's in parallel? Do using an 8D even make sense at all for starting?
Please help! I am a novice in all things mechanical and very lost at this point. Thanks!
elmoe is offline   Reply With Quote
Old 05-01-2009, 12:30 AM   #2
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: Help! What kind of batteries do I need for my bus?
Batteries in parallel should be the same. A pair of 8D's would do the trick, then again two 31's would do it, and also be easier on the back. School bus start batteries are over sized (2 8D's) to ensure the bus starts, even after it sits a while with cabin lights on, and with the school bus duty cycle.
ie: go with a pair of 31's, and install a disconnect switch for when you aren't using.
Old 05-01-2009, 12:33 AM   #3
bus-bro's Avatar
Same also means new at the same time.
Old 05-01-2009, 03:12 AM   #4
Coachwork: Richmond
Rated Cap: 69
Thanks for the info! What CCA should I shoot for on each of the 31s?
I see you are also in WA. We are up in Seattle, bus is stored down in Kent. Getting geared up for a trip in the schoolie to The Gorge for The Dead and Brothers show on May 16th.
Thanks again for all the help.
Old 05-01-2009, 07:15 AM   #5
the_experience03's Avatar
As high as you can afford. I'll post a better response later.
Old 05-04-2009, 12:11 PM   #6
Coachwork: Richmond
Rated Cap: 69
I put in two brand new 8D 1200 CCA batteries this Saturday. The bus fired up immediately. Needless to say I was overjoyed!
Thanks again for all the helpful input!
what kind of tank? BootsBus2011 Alternative Fuels | Electric, Propane, Wood & Biofuels 3 12-04-2011 10:32 PM
what kind of bus dieselman69 Conversion General Discussions 4 11-15-2008 01:53 PM
No! Not that kind of ga...(BOOOM!) Elliot Naess Everything Else | General Skoolie Discussions 0 10-17-2008 12:38 PM
Striping... and not the fun kind... Fifer Conversion General Discussions 1 03-24-2008 03:37 PM
1 of a kind 1 of a kind Skoolie Conversion Projects 2 09-09-2007 10:11 PM
