Old 01-11-2005, 09:57 AM   #1
Send a message via Yahoo to capttrips25
Help with speed (trans and rear end)
Some of yall have seen "willow" my bus. right now I have a new crate motor (IH 345) gasser. I was thinking of changing the rear end to a 2 speed and hoping the 4 speed transmission would be enough.
For further post, where do I find out what transmission and rear end I have? is there a number plate somewhere on them?
Sans Puer!!!
capttrips25 is offline   Reply With Quote
Old 01-11-2005, 12:24 PM   #2
Steve's Avatar
I have a IH 345 with 4 speed and 2 speed rear end. The low gear is really low 50 mph tops and I can do about 70 max in high.
Not sure what you are going for but having a two speed rear end will probably only help you driving around town.
Old 01-11-2005, 01:25 PM   #3
Re:
I was going for highway speed. As of now I can only do about 54 max and thats with the engine wound up at high RPMs. I have power, I can pull a mountain easy enough but I just cant make any highway speed.
Sans Puer!!!
Old 01-11-2005, 07:48 PM   #4
Send a message via Yahoo to phillip266
ring and pinion
i would take a look at changing the
ring and pinion gears before swaping to a 2speed it should be a lot easer than swaping the whole rearend that will be a Big job on a bus not to metion the ring and pinion gears you should beable to get what you need to get just the right amount of speed worth a try
Cool things happen when Great Minds come togather :)
phillip266 is offline   Reply With Quote
Old 01-11-2005, 09:08 PM   #5
Coachwork: Ward Genesis
Engine: DT466/MT643
If you have to change-out the R&P anyway, is it that much more work to swap to a 2-speed axle?
For highway speed, you probably want one (R&P or 2-speed axle) from a diesel truck...IF you have enough engine to pull it!
Jarlaxle
Old 01-12-2005, 12:24 AM   #6
a lot more
ya its a lot more work to change to a 2speed then to change the r&p
Old 01-12-2005, 06:15 PM   #7
lapeer20m's Avatar
I rode in steves bus with the 2 speed rear end. I was amazed. His bus is like a speed racer compared to my 6.6 liter ford with the at545.
It's been months since i rode in his bus, and i'm still jealous!
Old 01-12-2005, 08:09 PM   #8
rear ends
Well I have access to a pair of 2 speed rear ends. It was explained to me the Ford rear ends will basicly bolt up to an International Harvester.
I may try it out
Sans Puer!!!
Old 01-12-2005, 10:31 PM   #9
Engine: DT466/MT643
Lapeer: Your problem is the tranny. Bluntly, the Allison AT545 sucks. It sucks fuel & it sucks power because the converter NEVER locks up, so the engine is screaming, but you're not getting anywhere. Short of a tranny swap, I think you're stuck.
Jarlaxle
Old 01-13-2005, 05:41 PM   #10
lapeer20m's Avatar
I agree! The at545 sucks up a lot of power.
2 speed rear keith Conversion General Discussions 3 07-08-2012 11:51 AM
Ford diesel 5 speed trans frank-id Classifieds | Buy, Sell, Swap 0 11-08-2010 12:55 AM
1986 bluebird DT466/5 Speed man/2 speed rear code4 Classifieds | Buy, Sell, Swap 2 08-14-2006 11:29 PM
2 speed rear end.... Rocky624 Conversion General Discussions 2 05-15-2006 04:57 PM
WANTED: BUS WITH A DT466/MANUAL 5 SPEED TRANS lapeer20m Classifieds | Buy, Sell, Swap 7 08-10-2005 02:31 PM
