Old 05-30-2005, 06:03 PM   #1
Hey all almost ready to paint anyone know how many gals
im almost to the point to paint my skoolie does anyone know how many gals of auto paint it takes to paint one of these skoolies. thanks all. this is a full size bus. http://home.bellsouth.net/p/PWP-jrwon
heath692 is offline   Reply With Quote
Old 05-30-2005, 11:45 PM   #2
Year: 1981
Chassis: All American FE
Engine: Cummins 555 9.1 L diesel
paint amount
The quick and dirty: 5 gallons should do 2-3 coats.
I'm at the same point, and have checked the archive discussions for estimates and they vary depending on how you are painting and such.
A typical coverage amount for a gallon of paint is 350 square feet. If your bus is, say, about 35 feet long and 9 feet tall (a conservative one foot of ground clearance) and about that wide and is approximately one-third windows and other unpainted stuff like say wheels and tires, then you've got about 700 square feet of bus, including the roof.
I bought 2 gallons of primer and three of paint in case I need to do two coats (hopefully not given the priming).
I'm rolling it on and using foam brushes and regular brushes for trimwork.
Good luck, post pics...
Branden
Lucinda
1981 Bluebird All American
Branden is offline   Reply With Quote
Old 05-31-2005, 10:29 AM   #3
glock17's Avatar
Send a message via MSN to glock17
my painting story
http://getleid.us/modules.php?name=N...rder=0&thold=0
glock17 is offline   Reply With Quote
Old 05-31-2005, 10:55 AM   #4
dammitAndy's Avatar
Engine: 370
Rated Cap: 44
I got away with 5 gal, and had some left over. I just finished it the other day. You can check out my paint story too at
http://www.dammitandy.com/bus/05-spring05.htm
'89 Ford 370-2V Wayne - Sold :(
Plotting the next project now. Looking for a clean diesel pusher with low rust/miles. Identical plans with plumming and biodiesel added :)
dammitAndy is offline   Reply With Quote
Old 05-31-2005, 12:28 PM   #5
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Andy,
I really like your paint job. To tell you the truth, I didn't think it was going to look as good as it does. I just hope mine will look as good.
Robert
Roasting8 is offline   Reply With Quote
Old 05-31-2005, 01:49 PM   #6
dammitAndy's Avatar
Engine: 370
Rated Cap: 44
Thanks Robert! me either... are you refering to the computer drawing I had on my site?? I also started a new thread for my paint job...
http://www.skoolie.net/forum/viewtopic.php?t=782
Old 05-31-2005, 05:01 PM   #7
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Paint Estimate
I bought 4 gallons of paint, and I have about 1 1/2 left over (hmmm....that ceiling might look better in white than in green.....). I put two coats on with a roller, and I thinned the paint the recommended amount (8 ounces mineral spirits per gallon IIRC). I didn't use primer, but sanded down to clean paint with 100 grit and a 1/3 sheet orbital sander. I didn't have any rust to speak of anywhere on the bus, so I didn't have to deal with that issue.
If you use a roller, buy good roller covers. The cheap ones leave little pieces of lint that get pulled out of the roller in the paint. I don't know that the good ones won't, but I talked to a painter who said they didn't.
I rolled paint on a section and let it dry to the tacky stage while I rolled another section (about 3'x3' or so), then I went back with a damp, but depleted roller and re-rolled the tacky section very firmly. That eliminated air bubbles and "roping" (the streaks you get from the edge of the roller when you press too hard on it). Where the lint didn't come out of the roller and get stuck in the paint, it is hard to tell it from a sprayed on coat.
Disposability is your friend. Buy enough roller covers and some disposable gloves.
Have fun!
Eric von Kleist is offline   Reply With Quote
Old 06-02-2005, 02:18 PM   #8
vonslatt's Avatar
I bought 5 gallons, 3 green and 2 almond for the roof. I'm painting today so I'll let you know what I use. I'm using a foam roller and brush
More: http://www.vonslatt.com/bus-paint.shtml
Jake.
My 1989 Thomas Saf-T-Liner
vonslatt is offline   Reply With Quote
Old 06-06-2005, 12:26 PM   #9
vonslatt's Avatar
OK, got one coat on just about everything and I've used just about half the paint. I did buy an additional gallon of almond but only because I had mixed all of the original two with the ceramic additives and decided not the use the mixed paint on the window posts after all.
So, 5 gallon is just about right for roller/brush application of two coats of True Value XO-Rust.
Cheers,
Jake.
Old 06-06-2005, 07:15 PM   #10
Year: 1981
Great job
Jake, it looks terrific.
I think you missed a spot on the door, though.
Branden
Lucinda
new guy here ready to start pinky Conversion General Discussions 1 04-21-2014 08:24 PM
Ready but not finished. kc_4_jc Conversion General Discussions 27 03-12-2012 10:52 PM
Ready to purchase a bus. Need Advice! paulbruno International | Navistar Drivetrain 1 10-10-2010 11:30 AM
newbie getting ready to buy e-350 goshen - gas granolaeeter Conversion General Discussions 9 08-30-2010 03:52 PM
Getting ready to paint . . . vonslatt Conversion General Discussions 7 08-26-2006 07:27 AM
