Old 05-08-2012, 11:14 AM   #1
usmcbay's Avatar
Coachwork: Thomas MVP
Chassis: Saf-T-Liner ER
High Density Foam being sprayed today...
Well this has set me back a couple weeks waiting to get scheduled. My buddy is going to spray two layers of high density foam into the wall cavity's I made with 2x3 studs to hold my bead board. The electric will be run exterior with Galvenized hardware for looks and mechanics. Also the water lines will be hidden but exterior for maintenance reasons.
Been waiting to get this done but have gained SOME time pre-painting the beadboard a Corn Husk green with Behr Premium Plus... now I have to figure out how to Antique the walls a bit.
This is supposed to be Icebox/Freezer quality insulation and over the Rear Engine should knock down ever further what little noise there is...
Here's my Bus Conversion...
viewtopic.php?f=11&t=12202
usmcbay is offline   Reply With Quote
Old 05-08-2012, 09:53 PM   #2
usmcbay's Avatar
Re: High Density Foam being sprayed today...
Sprayed in and SOUNDS GREAT... It just 'feels' more solid...
Old 05-09-2012, 06:33 AM   #3
TygerCub's Avatar
Engine: Detroit
Looks really good too. Are you going to do the ceiling as well?
Old 05-09-2012, 10:06 AM   #4
usmcbay's Avatar
No the ceiling on a hot day isn't that bad plus I'm going to put the roll on Roof barrier. I may to cedar closet planks on the ceiling later - I have about 5" - 6" clearance and I'm 6'2".
Old 05-22-2012, 04:29 PM   #5
usmcbay's Avatar
Originally Posted by id stitch
If you don't mind my asking, what was your cost on this? I'd like to do the same but can't seem to find anyone up here that wants to work.
I paid $2.50 / sq ft... I was told the material was about $1.26 / sq ft. So Labor was $1.24. Not aggravated... but I had to pitch some Labor in myself!Okay... that was a bit aggravating.
Old 05-23-2012, 12:28 PM   #6
usmcbay's Avatar
Thanks,it sounds almost cheaper rigid foam after you factor in adhesives and all.
Really??? Good~! Glad to hear that because I was feeling a little sticker shocked.
This is some Tough Stuff too...
Old 07-31-2012, 05:37 PM   #7
somjuan's Avatar
Rated Cap: 71
Any idea what the R value on this stuff is?
7.3L Bluebird Conventional My build thread flickr bus.life
somjuan is offline   Reply With Quote
Old 07-31-2012, 07:26 PM   #8
GreyEagle's Avatar
R Value is $$$$........
I know that set you back a little..... Looks really good tho....
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 01-08-2013, 04:35 PM   #9
usmcbay's Avatar
Now that its winter time I realize it was the best money I put into it...
Old 01-08-2013, 07:02 PM   #10
lornaschinske's Avatar
Rated Cap: 89
One of the best things about the sprayed foam is that it seals up any air leaks. The worst thing is the price.
Is it worth it? The folks who have done it think so. It's not feasible for folks who are converting like we are (living in the bus and converting - quietly - as we get the $$).
Fulltime since 2006
Old 02-21-2013, 08:24 PM   #11
Year: 1974
Engine: Detroit Diesel 6-71
usmcbay,
If you had more room would you consider the spray on foam for the ceiling? We are looking at spray on to do ourselves, and found one where 1" = 6.7 R value and costs about $1.04 per sq foot. Definitely for the walls, but what about the floor? We plan on doing some insulation under the floor, as well as the actual underside of the bus and the ceiling.
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
Spray Foam Question White99z Conversion General Discussions 18 11-03-2016 11:26 AM
Expanding foam insulation PDBreske Conversion Tutorials and How-to's 10 02-25-2014 09:31 PM
Bus seat foam BUSBOZO Conversion General Discussions 7 01-17-2010 11:11 PM
spray foam under floor - who has done it? ramairws601 Conversion General Discussions 6 10-16-2009 06:29 PM
Using seat foam for insulation?? Lady Franklin Conversion General Discussions 2 12-10-2008 02:06 PM
