Old 06-12-2017, 08:15 PM   #1
Holes from seat bolts..
How did y'all patch the holes left from the seat posts ? I was thinking silicone, but I don't know if it will hold up
Sent from my SM-G955U using Tapatalk
brundige is offline   Reply With Quote
Old 06-12-2017, 09:16 PM   #2
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
I cleaned the holes and got rid of the rust then used fiberglass. cured quickly and worked like a charm.
3M Bondo-Hair resin fiberglass reinforced filler 762 - Read 1 Reviews on 3M #762
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 06-12-2017, 09:30 PM   #3
Hell yeah, thanks , gonna try it on wed.
Old 06-12-2017, 09:36 PM   #4
Good call. The fiber reinforced Bondo is light years ahead of the old original.
Old 06-12-2017, 09:51 PM   #5
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
We used to call that "kitty hair" or "tiger hair"
Rebuilt most of a floor in a rotted out 73 bronco with that stuff and some liberated no parking signs...
Old 06-13-2017, 10:44 PM   #6
Engine: T444e
Rated Cap: 35
I used 3M Dynatron 550 seam sealer to fill mine. The Bondo products aren't waterproof so you will have to get underneath and coat them to keep them from absorbing water.
bstewrat3 is offline   Reply With Quote
Old 06-15-2017, 12:59 AM   #7
tobeamiss's Avatar
I sanded away any rust, sprayed Rustoleum Rust Reformer, and then filled the holes with Henry 212 Crystal Clear. I love that stuff. A month later, it's rock hard solid and it ain't goin' anywhere. It was a great choice.
oh yes she did!
http://www.skoolie.net/forums/f11/to...-it-16557.html
Old 06-15-2017, 07:06 AM   #8
fwfw..the 3rd bus i converted was a 73 Flexible,(detroit); and the floors under the rubber matting was all skimmed bondo...all the wood was good, so inmy 93 thomas i did same forimperfections n holes
Old 06-15-2017, 07:12 AM   #9
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
I think I like this idea. Would it soak into a fiberglass mat, you think?
Old 06-15-2017, 08:59 AM   #10
tobeamiss's Avatar
I definitely think so. And a month later, since I haven't gotten to putting my floors down yet, I've tripped over the nubs several times lol. I decided to test one and try to yank it out...no go. The plugs are firm and not coming out. Super waterproof, so I'll be using it in several areas. I originally bought it to seal a window that was leaking.
oh yes she did!
Old 06-15-2017, 09:34 AM   #11
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Thank you
Old 06-16-2017, 05:17 AM   #12
tobeamiss's Avatar
You're welcome
oh yes she did!
Old 07-24-2017, 06:56 PM   #13
tobeamiss's Avatar
Did you try that and what do you think if you did?
oh yes she did!
Old 07-26-2017, 08:38 AM   #14
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Sadly, since I have purchased my bus, I haven't had a single day off. I am stalled for the near future. I see light at the end of the tunnel, and hopefully will get to something other than starting it and taking it on short hops around the neighborhood (but it is a head turner)
Old 07-26-2017, 09:14 AM   #15
tobeamiss's Avatar
Sorry you haven't had time, that stinks. I hope you get some soon. The heats been brutal anyway as you know and I've been sweating buckets. One day I was close to heat exhaustion and had to stop.
When you do get some time off and decide to use it, let me know how impressed you are ;)
Sent from my SM-T350 using Tapatalk
oh yes she did!
Old 07-26-2017, 09:15 AM   #16
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
I already bought 2 tubes of the Henry stuff lol. I will let you know!
Old 07-26-2017, 10:46 AM   #17
tobeamiss's Avatar
oh yes she did!
Old 09-02-2017, 04:14 PM   #18
Chassis: Ford B600
How did it work for you?
The Bowser Journal
Old 09-02-2017, 05:16 PM   #19
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Only did 4 holes as a test. Worked great.
Old 10-01-2017, 07:16 AM   #20
tobeamiss's Avatar
That's awesome. I haven't put my flooring in yet...It's been a year now of stepping all over them everyday and those plugs are tough.
I really like the Henry's crystal clear 212 and find I'm using it alot during my build. But also, all I do is plug up the tube with a screwdriver...can pick it up to use it a couple weeks later and it's not clogged and good to go. I also use it as glue for the felt strips I put around the windows when insulating. And... I fill in all gaps where water might enter around the window. And...I run a fat line of it along the bottom edge of the windowsill before replacing the windows.
It's good stuff. If you make a mistake, wait for it to set and peel it off easily.
I can't say enough good things about it and the many ways I've used it. I might even name my bus Henry when I'm all through LOL
oh yes she did!
