Old 12-27-2010, 02:27 PM   #1
hood insulation
I talked a bit before about this topic, on the hood of my bus there is a foot and a half of snow, so I started up the old girl(bus) she wasnt nearly as nosiey out side in front, and inside was noticeably quiet inside. then I shovled off the snow, it was a difference . inside and out. this means Ill be insulating the hood this spring, as well as the firewall.
just something I to share with everyone. (motor is 444 dognose bluebird.
Old 12-27-2010, 04:35 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: hood insulation
We used this on both the Class C (engine doghouse is inside the interior) and on the bus. Well, part of the bus. I ran out and had to cover the removable lid of the doghouse with Reflectix to keep the heat down. One standard "kit" did the Class C (I had two) but we had used part of the second kit on the food cart so I was a tad short on the bus engine cover.
http://www.jcwhitney.com/complete-in.../p2010772.jcwx
Fulltime since 2006
Old 12-31-2010, 09:36 AM   #3
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: hood insulation
I'm converting a FE Genesis, which has the driver's seat about 18" from a clattering DT466 engine. All I can say is: Dynamat! My friend has part of a 36"x50' roll left over from his V8 Miata project, and I plan to use all of it! I also plan to cover the "doghouse" with marine-grade carpet, probaably two layers of it. And make sure the doghouse gasket (on a flat-front) seals properly...if not, nothing else you do will accomplish all that much.
Also: on some buses (the BB TC1000 I drove, and my Genesis), the single noisiest thing seems to be the enormous cooling fan...mine is audible from 50'+ away.
Jarlaxle
insulating hood? gbstewart Conversion General Discussions 6 09-24-2010 10:07 AM
Helpful for the Hood Abbott Everything Else | General Skoolie Discussions 16 06-08-2010 06:39 PM
Range Hood GoneCamping Conversion General Discussions 2 07-26-2009 08:16 AM
hood bumper westport_wayne Classifieds | Buy, Sell, Swap 0 09-20-2006 05:01 PM
need hood latches for International bdavis441 Classifieds | Buy, Sell, Swap 1 06-07-2006 09:41 AM
