07-03-2009, 09:17 PM
Re: Hooking up air hose / air tool to the air break compressors?
Depends on you bus I guess... My Thomas had a 1/4" air fitting right next to the right side air tank underneath the bus. You might get underneath yours and look around to see it you got one also. The fitting on mine was gummed up and didn't work properly from years of getting road grime in it, but I picked up a new female fitting and some teflon tape and installed a new one. Works fine!!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
07-11-2009, 05:00 PM
Coachwork: carpenter
Chassis: international
Engine: 7.3 diesel
I just did my 1988 international truck. It already had a 1/4" water drain in the tank, I just unscrewed it and screwed in a 1/4" quick disconnect w/ some teflon tape. $4 from home depot. Works great. I was gonna put a tee and drain, but there wasn't room, so I will just drain it with male air fitting now and then.
Funny thing is this truck doesn't even have air brakes. The only thing that runs on air is the air bags that lower the truck, which I don't even use. Whatever, though.
07-11-2009, 06:46 PM
Engine: Detroit
Is that a Gremlin Bell I see dangling beside the air tank?
Good idea if it is! Keep the nasty beasties away!
07-11-2009, 06:55 PM
Engine: 7.3 diesel
It does look like a bell. That is the old air drain valve hanging by the pull cord.
07-12-2009, 09:11 AM
Chassis: Spartan (I think)
Engine: Cummins BT-6
Hi Ryan,
Just keep in mind that ANY air compressor system produces condensate, and water in air tools (impact wrench, air drill, etc.) is not a desirable thing to have. It would be better if you could install a "tee" fitting towards the top of the storage tank where the least amount of water will be found. I know it is more work, but it might save an expensive repair on your air tools. Just a thought.
Wish you the best!
"Adversity that does not kill you can only make you stronger."
Good Lord! I must be Superman by now!!!
07-12-2009, 06:53 PM
Chassis: Amtram
Engine: Navstar 190
Another consideration is many tools need a specific air pressure- too much can damage many nailers. Without a regulator you have no control over the outflow pressure. This set-up might be good for an impact wrench, drill or sander/griner... be careful of the operating pressure on other tools.
07-13-2009, 02:45 AM
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
RyanS: you have it half right. Put a male quick connect on the bus, where your photo shows a female. Your valve will then drain the air tank normally, without any further connections. Every bus I've ever seen (granted not that many) has it set up this way. Make sure and have a ball valve, which should have been there originally to drain the tank.
If it isn't grown, it has to be mined
07-13-2009, 10:09 PM
But putting a male fitting on will make it backwards to the way most systems are plumbed requiring either a double-ended female adapter or putting a female end on all the air tools. Ideally you would put a T in it with one end facing up and the other down. On each side of the T would be a ball valve and you would put a female quick connect above the upper ball valve. That way you could drain through the bottom, run your air tools off the top (without nearly as much condensate), and you would be able to isolate either to assure that you won't have leakdown.
07-25-2009, 10:57 PM
Engine: 7.3 diesel
07-28-2009, 06:51 AM
Chassis: Amtram
Engine: Navstar 190
I finally hooked up my air tanks to run tools here is a few pics.
You'll note I have a drain on the other side of the tank. Reason is I have two tanks, I did not put in a T junction would be a good idea if you only have a single tank. What I will have to do is hook up an air chuck and empty out the moisture before use. The regulator allows me to control outflow pressure, I can use my small airbrush, and paint gun without damage. As well some nailers don't use 120lbs. I have no way to know the CFM's on these- I'd imagine they have to be p there about 20. Anyone else know?
10-16-2016, 08:01 PM
Here I am again... Digging up a dead thread!
I walked away from a pneumatic pop riveter today at harbor freight after reading the air tank requirements.
I have no desire to lug around a 20 gal air compressor... I have no need for it!
I know that I can pull the draincock from the bottom of my air tank and install a nipple & air hose... But what about adding an old AIR TANK to the frame and feeding air into the top of it, and having a line out for hose. The air tank would be ballast, separate from air brake operation.
In theory it should work, but I don't know enough about air brakes to start re-routing stuff.
10-16-2016, 08:04 PM
you can do it... to be proper you should come off the secondary tank (the tank that feeds the #2 system).. and use a protection valve between the air system and the aux tank you install... the protection vaslve is a must.. it keeps you from running your bus air system down below the minimums required to operate the brakes.. it is required..
10-16-2016, 08:12 PM
I'm thinking I need to plumb in a ball valve near one of my bays and when I need to fill AND use the air hose, I can open the valve. Then when I'm not needing the auxiliary air tank, close the valve and I'm back to almost normal operation.
I sure see a lot of moisture come out of my tanks that make me think I only want to use the draincock to DRAIN the tank.
Are the air compressors we're using just a 'nature of the beast' thing?
10-16-2016, 08:49 PM
Rated Cap: 40 Prisoners
My bus has a built in Air dryer as should your bus. If your seeing a lot of
water coming out of your drains you may need to rebuild your air dryer
as the desicant and filter inside will eventually get plugged or waterlogged.
Fleetpride makes rebuild kits for many different brands and models.
10-16-2016, 08:57 PM
I boight a REMAN AD-4 for the DEV for about the same price as a rebuild kit and dessicant cartridge...
easy as could be.. bolted it on and much better operation.. I had a bad check valve so it short cycled all the time...
my new bus is hydraulic brakes but has air for air-ride rear, air seat, air door, so it has no air dryer.. but it does have an automatic moisture drain valve on the wet tank...
the nice thing to is if you set up your air for tools and such you can blow up your tires too..
10-16-2016, 09:22 PM
Rated Cap: 37,400 lbs GVWR
I put my Harbor Fright twin-tank 120 VAC air compressor above the front axle and connected it to the fourth air tank, the bus's accessories tank. There's also a HF filter/dryer in line with it to take out most of the moisture before the accessories tank, and a drain line from the compressor to a ball valve near my generator. Quick-connect air outlets for inflating tires and powering air tools are on each side of the luggage bays and in the engine room, and there's a pressure gauge to know exactly how much pressure is in the accessories system. Everything's connected with 1/4" DOT air line and Alkon DOT fittings. Easy!
This is one of the most useful mods I've done to the bus. It's really nice to use air tools without having to run the big noisemaker, and in an emergency I can also air up the entire bus air system.
10-17-2016, 12:54 PM
Coachwork: Crown / Pusher
My bus & I'm pretty sure most busses has a airline & valve installed to attach shop air & fill the tanks, on mine you can also drain the tanks why not just T off of that line with a fitting to run air tools ?
10-17-2016, 05:38 PM
Engine: Detroit 8.2
Never on a bus or any vehicle yet? Have I done compressed air but I have built many commercial systems.
If/when you do add to your existing lines I can only reccomend not tying into the drain/bottom of the tank.
That is where all of the sediment,sludge and water collects so anything added into there will be what receives all of that. Yes added protection stuff and ways of piping would help but why when all you need is to tie into a line or plugged opening off of the top of the tank. You won't be getting the gunk or the main amount of water in the bottom of the tank you will only get moisture that is in the feed tank if not drained properly/daily? Any added piping needs its own dirt leg(means the piping is horizontal with a tee for your tie in and at least 6" of pipe and a valve and cap to catch the dirt and water before it gets to your added tank.
I think that an existing air compressor was only designed to run your brakes or the original equipment to your bus and if and when we add to it? It should be used for emergency use only. I can see it filling a tire back to its proper pressure but not enough to set a bead on a rim and I think using your bus compressor to run air tools in your build will wear it out sooner than later? Buy an extra bus compressor to have onboard for when not if?
I will be adding an extra air tank and quick connects to mine but for only if/when needed? I did plan on a air ratchet to do lug nuts but I could get one broke and had to wait for the compressor and then I could get one more and wait? It was quicker by hand. And to take my mounted tire from 40-90 my air brake alarm that was holding the bus in place went off three times from starting and stopping the refill.
That was without an extra tank. Will have more volume with an added tank but once it's depleted then the same scenario will happen cause I am depending on one compressor designed for less than what I am asking of it
10-17-2016, 05:44 PM
the air compressors on our busses are fed oil from the bus oil system and are cooled with engine coolant... they are designed to be continuous duty.. the TU-Flo 501 (bendix) is rates at 11-12 CFM, the TU-Flo 550 Bendix is rated at 13-15 CFM.. (2 most common compressors found on IHC chassis school busses) these things can run a lot of stuff if we want them to and be happy doing it.. with air tools its going to be tough to outrun it.. of course the engine needs to be on.. you will drain a lot of air quickly if you just fill up a tank and expect to use a grinder or such...
the air compressors are unloaded when the tanks are full by way of a governor mounted on the compressor... when the air pressure reaches (usually 120-125).. an unloading valve is actuated so the compressor builds no more pressure... when the tank pressure drops to (usually 90), the compressor unloader is released and it can build pressure again... the pulley and rotating assembly spin anytime the engine is running...
10-17-2016, 07:21 PM
Engine: Detroit 8.2
Sorry my old 86-8.2 doesn't have all the bells and whistles. My air compressor does the job it was built to do. I have put it through its paces to see what I could expect of it. Of course other types and brands and models will do more or maybe less?
Good luck
