10-17-2016, 08:43 PM
#21
Coachwork: BB
Engine: Cummins
Rated Cap: 25.999K
Air Tank.
I just barely installed this myself. I put a ball valve on the drain of my furthest back tanks, ran a high pressure line to an auxiliary 30 gallon tank (mounted under the floor, behing the rear axle). At that tank there is another ball valve and a quick connect. I just crack both open to fill it, then once my tank is full, I close both valves. When I need air, I crack the valve on the aux tank and its good to go. It keeps the systems isolated. Works awesome, and Ive used it several times now. You could just run off the factory system, but you'd be limited on volume, and would have to wait for your system to repressurize before you could drive.
10-22-2016, 06:48 AM
#22
Most buses with air brakes have a connector for checking the line pressure that can be used to supply air if necessary.
There is also usually a connector around the drivers front corner for putting air in.
10-22-2016, 06:53 AM
#23
neither of my busses have said connections....
10-22-2016, 12:17 PM
#24
Year: 1994
I was going to put a ball valve and tee where i tap into the system. It looks fairly straight forward. I'm mounting a 100lb new propane tank for air storage. 40 gallons. I use all Dewalt tools for the most part but Id like to be able check tire pressure and change a tire myself.
Some one told me off my tank I need a 1" air line to get enough volume to a big gun for bus lug nuts. I also have a HF pan cake compressor i would like to incorporate off my invertor when I am park and dont want to run the bus engine and I'm just blowing off parts or sweeping the shop out with a air blower.
10-22-2016, 01:57 PM
#25
Engine: Detroit 8.2
That little bit of bigger pipe isn't going to change what can be provided buy your tank or whatever compressor feeding it.
To be safe I would say to look at your air guns/impacts manufacturers recommendations and upsize by one size. So if your gun runs off of a 1/4" air hose then I would run 3/8" at a minimum. And I would keep any hard piping with tee as short as possible unless supported properly.
10-22-2016, 02:27 PM
#26
On the farm we used to change about 5 10:00-20's per day during harvest.
We used a 3/4" drive brake over bar with the socket and extensions welded too it. We also had a big cheater bar.
09-10-2017, 03:23 PM
#27
Well, I finally pulled my head outta my butt and realized I already have a copper line plumbed to my deleted air door! With a switch on the dashboard and a secondary toggle switch by the door! Even an air regulator in the cabinet above the door.
I'm going to T off that and add air hose ports mid ship on both sides of bus, and it'll also help periodically with an air nailer. I know not to overuse the compressor, but I feel comfortable using it off and on
09-10-2017, 08:46 PM
#28
Originally Posted by Duckf00t
I finally hooked up my air tanks to run tools here is a few pics.
You'll note I have a drain on the other side of the tank. Reason is I have two tanks, I did not put in a T junction would be a good idea if you only have a single tank. What I will have to do is hook up an air chuck and empty out the moisture before use. The regulator allows me to control outflow pressure, I can use my small airbrush, and paint gun without damage. As well some nailers don't use 120lbs. I have no way to know the CFM's on these- I'd imagine they have to be p there about 20. Anyone else know?
Were that under my bus it would have already been destroyed going down a gravel road
09-11-2017, 07:14 AM
#29
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Makes me uneasy, as well. Just run that street el into he tank and get a short nipple to valve. I'd delete gauge-will have short life and can put it on quick connect if curious about psi.
Then run an airline for this:
Leslie RS5T
