Old 07-06-2009, 11:33 AM   #1
Steve's Avatar
Re: Hooking up the heater to a second radiator?
I think it would only work if you had an electric fan mounted to it. Even if you don't have the fan running the hot water flowing through the hoses makes the bus pretty hot inside in the summer. That is why most of us put valves at the engine to turn off the flow to those hoses in the summer.
If you need better cooling just put an electric fan on your normal radiator. I did that to mine and it stays at a nice 185 degrees. I think having the hoses that run to the rear heater will help also because you are cooling the water more often.
Old 07-06-2009, 03:45 PM   #2
Steve's Avatar
I think you could get by with just one fan, they work as both pushers and pullers. Put the fan between the radiator and hole to the outside. I would put a door to the outside so that you can close it when you are not using. In the winter it would heat the bus but help against condensation.
Old 07-11-2009, 07:26 PM   #3
Coachwork: carpenter
Chassis: international
Engine: 7.3 diesel
Case-
I just started an identical thread- I must have missed this one. Sorry- I swear I wasn't trying to steal your idea!!
Now let me go practice my "search button" skills.
I do think this is a good idea, though.
RyanS is offline   Reply With Quote
Old 07-12-2009, 09:24 AM   #4
Year: 93
Chassis: ?
An auxilliary radiator is a good idea. I had one on my 93 dodge/cummins for the transmission. It had an electric fan that came on automatically when needed. Usually, when pulling loads.
I also like the idea of taking advantage of the heat if possible....but how often would that be. It is relatively simple to hook up a auxilliary radiator. It is a different story to build something to be able to use the heat "when needed". A plenum with cable operated doors could be built to make it work but I come from the KISS way of thinking and I live in Texas where heat is plentiful. It is not wanted except for about two weeks out of the year. Therefore the benefit is minimal to non-exisistant compared to the time needed to design and build the contraption needed to make it work. Do you ever overheat in the winter when you could utilize the heat inside the bus?
K.I.S.S. - keep it simple stupid
Did you address the other reasons for possible overheating yet?
swhite832 is offline   Reply With Quote
Hooking up air hose / air tool to the air break compressors? GoneCamping Conversion General Discussions 28 09-11-2017 07:14 AM
DIY Heater for a Small Space: pulse jet heater lornaschinske Everything Else | General Skoolie Discussions 8 07-15-2012 08:54 PM
hooking air compressor hose to air tank? TikiBus Everything Else | General Skoolie Discussions 3 11-02-2008 09:10 PM
Need advice for hooking up my electricity Shrtbusdrvr Conversion Tutorials and How-to's 9 07-17-2007 10:10 PM
Hooking up stereo Chfsfn2 Conversion Tutorials and How-to's 1 08-31-2004 10:09 AM
