Old 02-14-2018, 02:27 PM   #1
Jdawgsfanasty's Avatar
How about 2007Thomas b2b?
Benz engine, 10R22.5 tires, transmission not stated...looks like a CE...just trying to learn stuff...
Jdawgsfanasty is offline   Reply With Quote
Old 02-14-2018, 02:39 PM   #2
brokedown's Avatar
Depends on where you live (fill out your profile!). In the US, the MBE engines are less common and parts are more expensive than their competitors. Also, a 2007 will be an EGR motor which is a whole set of issues we generally recommend avoiding. Conventional wisdom is to buy something made before 2004.
Old 02-14-2018, 02:56 PM   #3
Hmm...ok, saw it on govdeals...current bid is $1000...I can't make the move yet...but is the ecm accessible outside the dealer? Idk...it's 10yr old...I personally favor REs/pushers...
Old 02-14-2018, 04:14 PM   #4
Robin97396's Avatar
You know you can't get a motorcycle through that front service door. You're not thinking of HIKING when you go somewhere are you?
Robin
Nobody's Business
Old 02-14-2018, 04:58 PM   #5
Actually think I'd build a rack...
Old 02-14-2018, 05:02 PM   #6
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
When I ran a fleet of MB powered Freightshakers I had a couple of ecms repaired by a local place around here I would have to check my rolodex but if I could get it done here (St.Louis Metro) I'm sure almost any larger city. Gene
Gdog 5651 is offline   Reply With Quote
Old 02-14-2018, 05:03 PM   #7
Chassis: Bluebird
Rated Cap: 74
Won't she get mad?
Old 02-14-2018, 06:10 PM   #8
Thx for info...that seems to be the downside to some modern power plants
Old 02-14-2018, 06:11 PM   #9
Won't she get mad?
Hmm?
Old 02-14-2018, 07:31 PM   #10
I'd avoid anything after mid-2004.
Old 02-14-2018, 07:35 PM   #11
Lol...I saw a FE w/o power for $900...I would do that if I had money to work with
