04-24-2018, 11:16 AM
#21
Rated Cap: 44 or 66? 11 rows
Check the block casting number, too: if it's a "53" you will likely get a crack in the block (too thin). Cummins' Fatal Flaws - Diesel Power Magazine
04-24-2018, 11:52 AM
#22
Originally Posted by Dapplecreek
I think "likely" is an extreme use of the word here. Possibly, yes. Likely makes me think it will happen more often than not, and that's just not the case.
04-24-2018, 01:35 PM
#23
the block of a 5.9 will "crack" when you make a 2000 HP out of it
04-24-2018, 02:29 PM
#24
Didn't think that the buyer was going to modify it to 2000hp.
04-24-2018, 03:45 PM
#25
Chassis: Thomas
Engine: 5.9
So I think I got it.....
I got something saying second chance place minimum bid and automatically win item
It's at my original price 2110 plus fee
Does this mean I now have a bus?
04-24-2018, 03:56 PM
#26
Chassis: Thomas
Engine: 5.9
I've got 4 more hours at work, I'll figure out how I'm gonna get her home after that. Thoughts are appreciated
No CDL no time to reregister as rv 13+ hours from home, sound like an adventure
04-24-2018, 05:02 PM
#27
You're lucky I was mowing... I was gonna throw a bid at it at the last minute but missed out!
Congrats!
04-24-2018, 05:12 PM
#28
Chassis: Saf-T-Liner MVP ER
Call them. You might have to place another bid at the next minimum increment up.
04-24-2018, 05:17 PM
#29
that will happen sometimes if they want you to bid at the reserve price.. you'll see the minimum bid required... it can also happen if the high bidder told them they didnt want the bus.. the bid will go back to next minimum increment and if you bid that in a certain amount of time you get it...
04-24-2018, 05:23 PM
#30
Chassis: Thomas
Engine: 5.9
The bid says min 2110 I was the high bidder all the way
05-07-2018, 08:25 AM
#31
Chassis: Thomas
Engine: 5.9
Well bus is paid for I'm here to pick it up! I don't have to worry about the 53 because it has a cat in it.
Can't get it started with new batteries, no power at the key, I can turn the lights on
05-07-2018, 08:29 AM
#32
Chassis: Thomas
Engine: 5.9
Oh this thing is nicer than expected, dirty but nice.
No rust two AC units(hope they work) tires are good comes with permanent sc plates on it, has through side to side compartments under
05-07-2018, 08:44 AM
#33
First thing to try is make sure all the exit windows and doors are firmly shut.
05-07-2018, 08:51 AM
#34
Chassis: Thomas
Engine: 5.9
Tried that first, I'm outta ideas
05-07-2018, 08:53 AM
#35
Make sure trans in in Neutral?
And if its got the Vandal Lock setup and the exits/doors are locked the bus won't start.
05-07-2018, 08:54 AM
#36
When you turn the key do you hear any solenoids?
05-07-2018, 09:21 AM
#37
Chassis: Thomas
Engine: 5.9
Nope nothing
05-07-2018, 09:31 AM
#38
Is there no one who can offer any assistance at the bus yard or wherever you're picking it up from?
Was it advertised as running?
05-07-2018, 09:39 AM
#39
Chassis: Thomas
Engine: 5.9
Advertised as runs with a boost, called a mechanic got dash power air alarm comes on push button trans doesn't light up
05-07-2018, 09:44 AM
#40
Well if its not as advertised I'd be in the office letting them know!
