Old 06-07-2018, 05:03 PM   #1
Year: 95
Engine: Bluebird
How can I break into my locked underneath storage compartments?
The storage compartments under my bus, on the driver side, are locked shut and the locks are welded closed.
It doesn't smell like there's dead bodies in there, so that's good. But I think the heater valves might be in there and I want to shut off the radiator heaters before cutting, looping off and removing them.
I have tried a prybar but I just bent the sides of the doors, which doesn't seem like a good solution. I can see from underneath that the radiator hoses pass into the storage compartment. I've traced them otherwise and I can't find any valves.
I can't lift the bus at the moment. I do have an angle grinder. I'd rather not destroy the doors or the compartment.
What do?
elliot_peas is offline   Reply With Quote
Old 06-07-2018, 06:08 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I would think you could use your grinder to take off most of that lock then punch it in.
Old 06-07-2018, 06:28 PM   #3
Grind the 4 latch rivets off and the handle assembly should pop right out. Replace the rivets.
Old 06-07-2018, 06:32 PM   #4
Elliot Naess's Avatar
Engine: 5,9 Cummins
Or if there is room, hacksaw blade between the door and the body, to cut the pin or bolt (each side).
Elliot
Old 06-07-2018, 06:32 PM   #5
Year: 95
Engine: Bluebird
Cool thanks!
Old 06-07-2018, 07:09 PM   #6
Year: 95
Engine: Bluebird
Oh right because the mechanism is like the inside of my truck bed door
Old 06-07-2018, 07:19 PM   #7
Rivetboy's Avatar
Pound a square shank screwdriver into the key slot and turn it with a big crescent wrench and that cheap little pot metal lock will not even whimper when it breaks in half. Pull out the pieces and open the latch . The suggestion of grinding off the rivets will not work as the latch is still attached to the latch. Finally, sawing off the lock rod on either side still wont work easily and it forks everything up. If you destroy the lock cylinder it very inexspensive to replace and you can purchase the replacements all keyed alike .
Good Luck
Rivetboy is offline   Reply With Quote
Old 06-07-2018, 07:23 PM   #8
Rivetboy's Avatar
UH UH the lock rods are still attatched to the latch. Personal experince on this one.
Old 06-07-2018, 07:28 PM   #9
Good Luck
What do you mean the latch it attached to itself?Usually these locks are like pictured and once the rivets were out, pull the bottom of the assembly out and down, change out the lock. I hear what you're saying, but can't picture the other side of the latch.
Old 06-07-2018, 07:32 PM   #10
Rivetboy's Avatar
Mis typed It is not known what the insides look like and a lot of locks of this style have locking rods that are attatched to the latch and go into holes in the jamb to prevent from prying the door open. The lock cylinder is the easiest thing to destroy and the cheapest to replace.
