Old 03-13-2016, 06:06 PM   #11
roach711's Avatar
Rated Cap: 19
Originally Posted by Docsgsxr View Post
I know how I would do it, your picture didn't show any support for the middle hinge is all. No need to be brash.
No offense intended.
I tried to draw out the entire support structure but the drawing was confusing. The "distilled down" version was much more clear. Besides, the OP mentioned that he was going to have a carpenter do the build. My bad that I didn't see I wasn't replying to him.
The Roach Motel
roach711 is online now   Reply With Quote
Old 03-13-2016, 10:03 PM   #12
Engine: 7.3 L
I think it is just a slide out that sits on top of another piece of plywood. So the face of the bench moves forward and supports the bed. While the frame of the bench stays put and supports the middle.
Maffei is offline   Reply With Quote
Old 03-13-2016, 10:09 PM   #13
Engine: 7.3 L
Maybe with a small lip that catches to top plywood when extended out to keep the whole bed level?
Old 03-13-2016, 10:28 PM   #14
Engine: 7.3 L
Or maybe like this...
Old 03-13-2016, 10:30 PM   #15
Alan N's Avatar
Year: 1975
Chassis: Gillig
Originally Posted by roach711 View Post
Use #23A56CV anti-gravity modules at the front seat edge. .
What is the weight rating on those antigravity modules?
I'd like to lift about 24,700 lbs.
Alan N is offline   Reply With Quote
Old 03-14-2016, 07:55 AM   #16
Then I'd suggest the #23A56HDCVs.
Deezl Smoke is offline   Reply With Quote
Old 03-14-2016, 09:26 AM   #17
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
all is good. Makes sense now that you explained it.
Old 03-14-2016, 09:55 AM   #18
sammy's Avatar
Coachwork: Gillig
Chassis: Phantom Schoolbus
Engine: Detroit Diesel 6v92TA
that's what I would have guessed too... maybe he used flat plywood instead of the interlocking rails (but I think the interlocking method would work much better).
sammy is offline   Reply With Quote
