Old 03-28-2012, 11:14 AM   #1
usmcbay's Avatar
Coachwork: Thomas MVP
Chassis: Saf-T-Liner ER
How did you Patch Light Holes??
Just wondering how you guys patched your Flasher Light Holes??
Back it with Sheet Iron and Tack it?
Here's my Bus Conversion...
viewtopic.php?f=11&t=12202
usmcbay is offline   Reply With Quote
Old 03-28-2012, 11:56 AM   #2
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: How did you Patch Light Holes??
FRP circles screwed on, with 3m 5200 chaulk liberally applied. Someday I'll do a better 'fix. Someday.
Old 03-28-2012, 01:20 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Aluminum plates,riveted with silicone
Old 03-28-2012, 02:27 PM   #4
right now i have metal panel screwed over them.. however, that cause its winter... proper way it to make a 18 ga circle and mig weld them in... when i make a slide out i will get around to that..
Old 03-28-2012, 04:51 PM   #5
replaced the lens with clear ones. other wise would have skinned over with sheet metal screwed and sealed
Old 03-28-2012, 05:12 PM   #6
usmcbay's Avatar
I can get a 4' x 10' of 18ga Sheet Iron for $62.32 here in Houston. I think I'll cut the two circles out in one larger rectangular piece and then use that as a template to cut my 18Ga Sheet Iron... tack it in and then do the body work from there... I can sell the remaining 18ga Sheet Iron on Craigslist or hang on to it for future use.
Old 03-28-2012, 09:19 PM   #7
Engine: DTA360
Rated Cap: 16
I replaced the lens with clear ones...
dirtygoat is offline   Reply With Quote
Old 03-29-2012, 12:00 PM   #8
bus-bro's Avatar
Originally Posted by Iceni John
.... but so far nothing's been easy - if I wanted easy, I wouldn't have bought a bus in the first place!
Ain't that the truth.
Old 03-30-2012, 02:33 PM   #9
usmcbay's Avatar
I've got some sheet iron - I'm going to go in through the Front First Aid Kit door and put some coupons behind the holes... tack them in weld them out then smooth it out.
Old 03-30-2012, 04:42 PM   #10
lornaschinske's Avatar
Rated Cap: 89
I filled the holes with the huge lights! IT WAS REAL EASY!
Fulltime since 2006
Patching holes in the floor swhite832 Conversion General Discussions 39 09-10-2021 07:44 PM
holes from bus seats thewallfan Conversion Tutorials and How-to's 8 04-21-2015 04:41 PM
Necessary to patch floor bolt holes? mtunderwood Conversion General Discussions 10 12-10-2014 12:14 PM
Punching holes in my roof - best way to seal em? Lightfoot Conversion General Discussions 14 09-03-2014 01:50 AM
Sealing holes in floor firemanbud343 Conversion Tutorials and How-to's 10 09-27-2009 10:00 PM
