Old 09-19-2012, 05:39 PM   #1
Engine: International T444E
Rated Cap: 71
How do I go about doing this?
I want to remove one of the rear windows and install a window A/C. How do I go about removing the glass without breaking it? If possible I'd like to keep it as a spare. Do I just cut the gasket? Thanks.
mchunt is offline   Reply With Quote
Old 09-19-2012, 06:12 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: How do I go about doing this?
Don't cut the gasket!
Mine is a BlueBird. The OUTER side of the gasket has a spline in it. Find where the spline meets. Start there. I found a paint key like what you open paint cans (and beer/soda bottles) with worked great to start pulling the spline out with use the hooked end you normally use to open a can lid). Wet and soapy makes the job easier. Once the center spline is out, we very carefully pushed the gasket & glass INSIDE using the hooked end of the paint key & some wooden craft/popscicle sticks to flip the outside thin edges of gasket onto the glass and past the metal body sheet metal, This is a two person job (one inside/one outside) if you can get someone to help. Once out, wash the gasket in laundry detergent with a little bleach added to kill any mildew that may be on the gasket.
Fulltime since 2006
Old 09-19-2012, 07:24 PM   #3
Rated Cap: 71
Thank you so much.
Old 09-19-2012, 08:46 PM   #4
Lorna is right but I'd add the reminder not to nick the edge of the glass. If it is not tempered or is laminated you will start a crack and if it is tempered the glass will expolde into a million pieces.
Old 09-22-2012, 04:19 PM   #5
Rated Cap: 71
Thanks for the good advice. I found the spline. I'll post some pictures of the removal when the gallery is back up.
