Old 05-08-2011, 04:34 PM   #1
Year: 1985
Coachwork: GMC
Chassis: Chevrolet/GMC B-Series
Engine: 366 Industrial
How do I replace an ignition switch? [Fixed pictures]
I have a 1985 GMC school bus which needs a replacement ignition switch. The ignition switch is next to the choke, not part of the steering column, so it should be easy. Unfortunately I couldn't find the answer anywhere after much searching.
Here's what the replacement looks like, front and back:
I was able to unscrew the front face plate of the old switch about a quarter inch, but it doesn't want to come all the way off.
This is apparently normal, because the front face plate of the replacement switch (which had to be cut out of a junked bus) also only unscrews a quarter inch:
Is there a way to unscrew it all the way? Am I going about this wrong?
Thanks!
fingerplay is offline   Reply With Quote
Sleeping bed mounting: fixed, or folding/stowable? Ryan Grimm Conversion General Discussions 10 12-08-2017 06:00 PM
Ignition cut-off problems CostelloCrew Conversion General Discussions 4 11-06-2014 07:00 AM
Transfer Switch dead; Burned relay; Replace it? Redbear Conversion General Discussions 1 03-04-2009 02:59 PM
fixed head light thanks joshritchie Everything Else | General Skoolie Discussions 0 12-05-2008 03:43 PM
electronic ignition lapeer20m Everything Else | General Skoolie Discussions 15 07-17-2006 08:42 AM
