Old 05-31-2010, 01:21 PM   #1
How do we remove the windows?
We were told they just pop out real easy, but we haven't been able to figure out how to "easily pop them out"
Any info would help out greatly.
tks
Old 05-31-2010, 07:57 PM   #2
Re: How do we remove the windows?
Originally Posted by Smitty
If you've removed the screws all that's holding them in is sealant, pry them out....just be careful if you plan to re-use them. I think someone posted they used a heat-gun to soften the sealer which made the process easier for them.
Smitty
I see two screws one on each side, thats all I can find, they seem to just keep the lower window in, Ill try tommoro and see if I can get the frame out, looks like there really glued in good!!
tks
Old 05-31-2010, 11:19 PM   #3
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Heat gun! That's what I used to soften the adhesive. Heat them up good around the edges and they pull out a lot easier.
Old 06-02-2010, 07:43 PM   #4
I got figured out, they poped out brute force and ignorance!! we dont need no stinken heat gun!!!
after looking real hard at them I figured it was just the caulking holding them in , with a bit movement they came right out>
thats a bunch for all the help with this.
Ill have more questions soon
Old 06-03-2010, 08:11 AM   #5
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
We made sure every screw was unscrewed and even took out a few screws from the top metal above the windows so we could slide them out. Then we used a crowbar and bent them out, this is what it looked like.
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
how to remove sidepanels ???? swinada Conversion General Discussions 4 06-05-2018 06:44 AM
Remove or Not to Remove - Rubber Floor... usmcbay Conversion General Discussions 29 01-14-2017 05:44 PM
How to remove rear windows - Bluebird White99z Conversion General Discussions 7 07-26-2016 02:41 PM
Screening original windows and installing RV windows skoolz out Conversion Tutorials and How-to's 3 10-27-2010 01:54 PM
How do I remove the windows from the front door of my bus? dogfinn Conversion General Discussions 18 05-26-2010 01:26 PM
