Old 06-01-2010, 01:08 PM   #1
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: How do you connect multiple fresh water tanks together?
Just plumb a pipe between the tanks at the bottom. You may also need to plumb a smaller vent tube between them at the top. This will allow both tanks to fill and equalize the amount of water between them. Of course this will only work if you have them both at the same level.
Fresh water inlet and draining BUSBOZO Conversion General Discussions 6 03-21-2010 07:13 PM
12V Water pump for fresh water? ezbme Plumbing, Water and Waste 1 05-29-2009 07:26 PM
Looking to connect .. using water/alcohol frank-id Everything Else | General Skoolie Discussions 0 01-02-2009 10:05 PM
fresh water tank bocephus Everything Else | General Skoolie Discussions 5 12-21-2005 09:01 PM
Fresh Water Systems Steve Conversion Tutorials and How-to's 0 06-16-2004 01:38 PM
