07-29-2014, 04:10 PM
How far will $1000 get you in a conversion?
I'm looking at purchasing a bus and was looking to initially invest $1000 into converting it and was curious if anyone had an idea of how far I could get....
I'm looking to rip out seats and do flooring, then I was thinking of electrical and water.... The bus I'm looking at is already painted black so I don't have to do that.
And while you're here, if you have an idea of how much it cost you to do specific parts in your conversion (I.e. Electrical, Plumbing, A/C, Insulation,etc.) that would be appreciated as well...
Thanks!
07-30-2014, 08:06 AM
Re: How far will $1000 get you in a conversion?
I have no experience yet, but I was thinking it might help to tell everyone what your goals are in this conversion. Veggie? Roof deck? Septic tank? Propane stove, hot water heater and heater? Bathroom? Outdoor shower? If you give this kind of information (floorplan maybe?) Then I bet others could better answer your question.
07-30-2014, 09:03 AM
Depending on what you're looking for to get out of the bus, $1K won't be enough to do it unless you're going for a Hunter's Special.
I'm thinking it will run between $8K-$10K for my bus, not including the purchase of the bus. It might be less, since we have to build cabinets to my height (I'm short), but it might be more since we have to locate appliances that are special in size as well.
But, like I said, it really depends. Using different appliances, tools, woods (I'll be using Maple stain grade wood, much pricier than anything else, for the bed alcove since it won't be painted), tiles, carpets, water systems, showers, tanks... it's all massively different in price depending on what you're using.
Can you build a bus with $1K? Sure. It'll look somewhat like that crappy Architect Kid's bus (it really shouldn't count as a conversion, seeing as it had no bathroom or much in the way of a kitchen... I'm sorry, I just really hate that kid. Liked his wood stove, though), but it can be done. Nothing will look finished and you probably won't get the flooring in place (which can cost you anywhere from free to $400 and up depending on materials). But ya can still give it the ol' college try. Won't hurt nothing and if ya can do it then more power to ya and if ya can't, well, learning experience if nothing else. And you'll still have the bus anyhow so keep a log of what you're spending to see just how cheaply you can go. Should be able to find some shoestring budget buses on here by using the search function and those are always fun to see. Humans are a creative lot, after all.
What's your location? Do ya plan to travel? Where to? That would help in the way of what kind of heating/cooling you'll be needing.
'Tace
Dog is my copilot. As I have no dog, I have no flight plan.
"If all porkchops were perfect, we wouldn't have hotdogs!" -Steven Universe
07-30-2014, 10:05 AM
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
I did mine for about $1,000. But Its just 2 used futons and a portapot and ice chest and fan and electric heater with a $500 Hyundia generator. Sooo, yes you can but it ain't plush.
07-30-2014, 12:27 PM
Year: 1987
Engine: DD 8.2L
In our conversion (not counting the bus itself) we passed the $1000 mark just after the the rough framing went in. So $1000 got us gutted bus, stripped sealed and painted steel floor, vapor barrier, insulation, plywood subfloor, and wall studs. Depending on how in depth you want to make your conversion will determine how far $1000 will get you, but I agree with Das Mel in that it won't get you far... YMMV
07-31-2014, 11:15 PM
Got a link?
08-01-2014, 01:59 PM
Engine: 5.4 litre
Rated Cap: 12
You do relize that she is talking about the Brady Bunch sit-com from the 70's????
Got a link?
08-01-2014, 02:24 PM
Got a link?
http://www.hankboughtabus.com/
'Tace
08-01-2014, 02:48 PM
Location: Alachua County, Florida until we get out of there
He's got some good ideas about modularity of spaces, but overall, I rate it as it works and I'm jealous that he has a bus.
Definitely an architect, not a carpenter.
And not using the front door to enter and exit? I would think he would partition off the driver station when it is non-mobile. But not using the front door and walking directly into the bathroom???? Ewwwwwwwwww.
But I am still jealous, the bastard!!!
08-03-2014, 04:30 PM
Chassis: AARE
Engine: 3116 Cat 250hp
I spent almost $1000 on the paint.
08-08-2014, 07:57 PM
I haven't done it, so I can't say for sure, but if you have the time and ability to scrounge for parts rather than buying everything new, you can save a lot.
Some people have torn apart old camping trailers to get all the hardware, plumbing and mechanicals, and then scrapped the hull. I have heard of cases where an old camping trailer, perhaps water damaged, can be had for just taking it away. I should be so lucky. I almost had one lined up, offering to help a now-retired co-worker demolish an old camper. He only wanted to re-use the trailer frame to make a utility trailer. But after retiring, he got a new truck and Travel Trailer, and now he and his wife are home less than 6 months per year. I did get one or two boxes of old "goodies" cleaned out of his basement.
I save old switches, nuts, bolts, boards, and plumbing parts. If I need a particular bolt and can find it in the bolt can, that saves maybe 85˘ at Home Depot and the $3.60 in gas to get there and back. Multiply that by a dozen or so and it begins to add up. With electrical it is even more. An old radio or appliance headed for the dumpster might have a switch or relay that would be worth $10-$15 new. A good piece of left-over plywood from a shipping container saves at least $20. My tool boxes have better-than-new replacement latches from shipping crates, and one has a handle saved from a 1960's fire truck radio. And new copper pipe is being priced out of existence.
Most of the towns around here have one day per year when the highway departments will pick up large items for disposal. You can cruise the neighborhoods to find old counter tops, cabinets or sinks among the old bicycles, fake wood entertainment centers, arm chairs and the like.
Some people give things away on Freecycle.
To be frugal, you need advance time, storage space, and the ability to visualize re-purposing cast-off or yard sale items. These method will not work if you buy a bus and are in a hurry and need to be full-time in 3 weeks for a new job at the other side of the country.
I'm also shocked by the price increases of everything. Last year's $1000 seems to be this year's $1300.
[GEEZER VOICE] "I remember when you could but a BRAND NEW car for $1595!" [/GEEZER VOICE]
08-08-2014, 09:33 PM
Rated Cap: 89
To get an idea of what your conversion will cost, add it up. You really can't get an idea based on other people's conversion budgets. Too many variables.
Make a fairly comprehensive list of what you want in your conversion. Get specific. Then use the internet to find prices. That will give you a starting point on figuring conversion costs. Using full sized appliances will be cheaper (and safer in some cases) than using RV stuff. It will also allow you to buy used appliances as well at a decent price. Craigslist, flea markets, yard sales, etc will yield stuff that you can repurpose. For actual buying (not for pricing purposes) use amazon.com as you can often get some really good buys (watch out for shipping charges). Like Redbear said, short time frames will cost you money. Lack of willingness to learn how to repurpose new or used items will also cost you money. Inability/unwillingness to think outside the box to adjust typical building methods will cost you money. Lack of a plan will cost you money.
How far did $1000 get us? Hard to tell. We had moved into the bus before we hit that point. It was little more than a painted partially insulated metal tent with a working toilet, limited running cold water, cooking (owned the full size residential range... love my range so much that we paid storage fees to store it for 4 years and had a small microwave already which has since burned up and been replaced with another $100 microwave not counted in the conversion budget although the used washer & dryer as well as the LP conversion kit is included) and refrigeration (owned the freezer, one refrigerator and bought a used dorm refrigerator for $10 at a yard sale). We had a lot of stuff that we had bought, bartered, repurposed or been given before we started converting. We are almost finished and are up to about $5400. We have splurged a bit on some things and decided to upgrade a little (like using ceramic tile rather than plastic laminate for galley countertops). We added an LP firebox ($369) to put in the fireplace mantle ($0). The flooring that we have finally decided on (and may push back on installing) will run a tad under $400 (I need to refigure the square footage needed). Our proposed budget is $6K. Our goal is to try and stay as close to that amount as possible. We figure we should hit about $8K by the time we are finished due to increasing materials pricing and the upgrades we have decided to do (like the new dishwasher that we plan to buy during the Black Friday Sale in November).
08-08-2014, 10:31 PM
my first $1000 was 3 batteries and a tank of fuel.
08-11-2014, 01:58 PM
Rated Cap: 19
A grand won't get you very far unless you plan to be pretty minimalist in the creature comforts. It's amazing how much the incidental stuff like adhesives, fasteners, paint and lumber costs. I made what I thought was a comprehensive cost estimate before beginning our build and ended up nearly doubling it.
The bus mechanicals will likely need some work themselves and that grand could easily melt away before you even get to the conversion.
Here's a link to my cost list:
viewtopic.php?f=36&t=11224&start=330#p584868
