Old 09-17-2018, 07:11 PM   #1
Thumbs up How long does it take to convert a skoolie?
Greetings from the Hoosier State! My wife and I have decided to take the plunge and order a Skoolie RV. Can anyone tell me how long a professional conversion would take? We are considering a cab-over, 41' model. Any information will be appriciated.
David914 is offline   Reply With Quote
Old 09-17-2018, 07:29 PM   #2
Johnny Mullet's Avatar
Engine: T444E 7.3L
Took nine months to convert mine. Link to build below........
Old 09-17-2018, 07:46 PM   #3
We're not professionals. We're DIY'ers. Mostly, anyway.
Old 09-17-2018, 09:28 PM   #4
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
How long?
I would approach this question from a couple of view points. One like having a custom house built, If you make changes, After the work is started, You will add time to the work, and expense.
Two, a custom built street rod, Nothing is standard off the shelf, that is the way behind "custom". If you have one guy doing the work for you, or a crew of ten.
Both could take the same amount of time. Some one here hired a neighbor fellow that was very very good with wood, The time he took and the level of fit and finish, I would call this cat "master" wood worker. There are damn few "master" of anything. The closest I can think of are people that outfit boats, planes, and way way expensive tour/coach buses. School bus, crew of five to seven, making 30 to 50 an hour four weeks or less.
Most here are amateurs and many do very good work. Because this is not our every day thing 8 to 12 hours a day... we do an hour here five hours there..... takes a year or more.
sorry I can not answer your question, but with rare exceptions, any one that can say it will take x number of days, is lying to you.
Only someone that is doing this every day is the most likely to be able to answer this question. and even then, it goes back to that thing about making any changes after you start.
william
Old 09-18-2018, 01:38 PM   #5
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Is the builder giving an estimate of time?
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 09-18-2018, 01:49 PM   #6
My first bus was substantially completed in less than three months.
I have been working on my current bus for two years and have made about as much progress as I had made on my first bus in the first two weeks of work.
It varies significantly depending on difficulty of your particular build, your time availability, your personal skills and what kind of help you have with the project.
I have seen a few builds that are moving steadily forward after 10+ years of work.
