05-05-2019, 10:33 AM
How much diesel can you skoolie hold?
I was trying to decide how to make this decision. The question that I think would be useful - what is the longest stretch of road in the US or Canada without services? Another aspect - I know that fuel prices can vary dramatically from one state to another. Any dialog? I am not crazy about the idea of carrying fuel cans to store extra diesel. I want it all to be tucked away safely under the bus between the frame rails.
05-05-2019, 10:55 AM
Another advantage to larger tanks is not just being able to get further on a tank but also to have more flexible as to. Where you stop for fuel.
Gasbuddy.com has a trip planner to help you find the lowest cost fuel on your route. With greater range you can optimize your stops and stick with the lower cost fuel stops.
Try it out. Plug in all of you bus & route info, look at fuel cost then change your tank size and run it again. You will see the advantage of the larger tank even when services are readily available.
05-05-2019, 11:04 AM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
one tank or two
I have a 40 gallon tank, I am considering adding another 40 gallon tank. 11,000 pound 23 foot long short bus, expecting more than 11 miles per gallon so effectively 800 mile range with two tanks..... have not decided yet
william
05-05-2019, 11:06 AM
My Genesis has a 60ga. tank, there is a 100ga. tank available for it.
05-05-2019, 11:16 AM
Chassis: IH
Mine has a "30 gallon" tank (actually more like 30 usable gallons, tank itself is probably closer to 40, from bone dry to overflowing). Since I plan to rack up some miles on it, I feel a considerably larger tank is in order. I'm debating cannibalizing one from a road tractor in the 100 gallon range.
Since mine's a shorty, I only have ~54" between the steps and wheel arch, so using a longer tank isn't an option. I had considered dual tanks, but the other side has the exhaust routed in front of the tire (I could re-route it, but...) and the air tank (I'm not so into relocating this). So the second tank is out unless I put one behind the drive axle between the rails. It can't go on the right rear because wheelchair lift, and it can't go on the left rear because tool box.
As I recall, a 25" diameter tank, 52" long is close to 100 gallons. (Some quick math shows ~25525 cubic inches = ~110 gallons, but tank makers rate under that for expansion). At ~10 MPG that would give me a mathematical cruising range of 1100 miles, but probably closer to 800-900 comfortably, and realistically probably half that before I'll want to stop and rest, eat, and whatever else.
05-05-2019, 12:53 PM
Rated Cap: 37,400 lbs GVWR
100 gallons here. The Crown Super IIs that originally had methanol engines have huge tanks, I think about 200 gallons, because methanol has lower energy density than diesel, and they kept them when they were later repowered to diesel. I had thought about putting in an extra tank between the frame rails just ahead of the fuel tank, but I've now used that space for my emergency air compressor instead.
05-05-2019, 04:42 PM
Coachwork: AMTRAM
Chassis: INT
Rated Cap: Big Girl
My rig has a 100gallon tank, it's mounted in the very rear of the bus behind the axle. I get about 10 1/2 MPG so I can easily go 1000 miles on a full tank. It's a nice thing to have.
05-05-2019, 04:54 PM
Mine has a 65 gallon tank and gets 10 mpg (I think). 650 mile range seems like more than I would need.
05-05-2019, 04:55 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
have to take out a mortgage here in BC to fill that tank at $6.00 a gal ( Imperial Gal )
05-05-2019, 05:01 PM
Chassis: IH
Considering I saw fuel at 2.83/gal yesterday ...
05-05-2019, 05:30 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
better, but even so, that takes a chunk of cash to fill that one up :O
05-05-2019, 05:33 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
100 US gallons in a midship tank; 7 mpg
05-05-2019, 05:50 PM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
182 gallons - 1200 miles-ish. Couple more advantages - choice of fuel stops (best pricing) and, if using diesel for heating - lots of heating "time."
05-05-2019, 05:54 PM
Engine: DT408
I built dual 70 gallon tanks for my skoolie.
140 total.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
05-06-2019, 03:15 AM
2000 international thomas 38, had a 67gal. located on passenger side rear of the door, inside a cage. Now dual 60 gal saddle tanks for 120gal of fuel, 112 usable.
05-06-2019, 08:14 AM
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
New Flyer coach bus - 160 U.S. Gallons. Haven't had it on the road yet to know its actual mpg, but the model prototype engineering report says this bus should get 6.7mpg on average. ECU has 4.0 mpg lifetime cumulative, but this bus' previous life was a city bus, so take that with a grain of salt....
05-06-2019, 08:30 AM
Engine: T444E 7.3L
I also have a 65 gallon tank and get 10 mpg with my bus.
05-06-2019, 09:27 PM
Chassis: Thomas
Engine: CAT 3126
100 gallons
05-06-2019, 09:29 PM
45g and 11mpg.
Don, Mary and Spooky the cat.
05-11-2019, 03:24 PM
$2.35/gallon gas at 1 gas station in Hendersonville TN.
$2.42/gallon gas at Costco West Nashville.
$2.69/gallon diesel Lebanon TN.
My 2001 Former ATF 4WD 3500 Chevy Express Bomber Van has an automatic fuel tank switching system with holds 70 gallons total. At 13 MPG with a 8.1 Liter (496 CI) engine the large fuel capacity is a nice thing to have.
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"
