Old 05-18-2018, 02:34 AM   #1
How much does your converted bus weigh?
Hey!
I'm doing some homework and trying to figure out if an EV conversion for a bus is possible/sensible, I have a thread about that in the electrical section... not too important to this thread, but I figured I'd explain why I want to know.
So, how much does your converted bus weigh?
What I'm going to try to do is compile all the info shared with me here into a Google Doc and share it with everyone including things like averages, minimum, maximus... and depending on how much and how granular the data I have to work with is, maybe I can give some other useful numbers.
Please, be as detailed as you can be! If you have weight before and after conversion, that's great. If you have model numbers, how many seats/windows the bus has/had... how much the wheelchair lift weighed, if it had one... all of that would be awesome info to have!
Thanks.
scapegoatwax is offline   Reply With Quote
Old 05-18-2018, 07:08 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
1991 Bluebird AARE GVWR 36,200
Seated with full fuel tanks (100 gl)
Front axle 8,720
Rear axle 15,360
Gross wt 24,080
Converted mostly done except for cabinet doors
Full fuel (100 gl) and fresh water (100 gl) driver in seat (180 lbs)
Front axle 10,640
left 5580 right 5060
Rear axle 17,440
left 9140 right 8300
Gross wt 28,080
Old 05-18-2018, 07:31 AM   #3
Chassis: Saf-T-Liner MVP ER
Thomas Saf-T-Liner 1999.
40', Cummins 8.3 and MD3060
Completely stripped of seats, walls, and ceiling:
Steer Axle: 6360 lb
Drive Axle: 12400 lb
Total: 18760 lb
Steve Bracken
Build Thread
Old 05-18-2018, 07:46 AM   #4
2kool4skool's Avatar
F 9640, R 9647 w/both of us on board.
Don, Mary and Spooky the cat.
Old 05-18-2018, 08:02 AM   #5
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Engine: DT 466e/MT 643!
Rated Cap: 16
Front 7200
Rear 12200
Trailer 4100
Total 23500
On our way up to Montana for the summer loaded with our stuff and towing our Ford Escape.
johnbloem1974 is online now   Reply With Quote
Old 05-18-2018, 07:02 PM   #6
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Steer Axle: 6360 lb
Total: 18760 lb
My stripped 40' International is almost exactly this front and rear. I'll weigh again once it's done. The GVWR is over 26K - maybe 31? Can't remember.
2martins is offline   Reply With Quote
Old 05-20-2018, 02:39 AM   #7
Alright! This is a good start. I guess it's no surprise, but buses are quite heavy! Haha
Here's what I came up with so far off of these replies. Let me know if I can make this easier to read or more useful!
Do any of you happen to know what material your buses' frames are made out of? What about the wheels?
Another shot in the dark, but what about the weight of the engine/transmission, as those probably wouldn't be a part of an EV conversion. The transmission might stay.
Old 05-20-2018, 06:31 AM   #8
Chassis: AARE
Frame is steel, what else could it be? Wheels are steel. 40 feet long.
Cat 3116 engine dry weight approx 1085
Allison 643 trans dry weight approx 510
AARE is rear engine
Old 05-20-2018, 06:43 AM   #9
I know a DT466 weighs around 1500lbs without the transmission.
With ALL the interior stripped out, the rolling shell weighed 17,900 lbs and it was a 40 footer FE.
Roll Your Own Build Thread
Old 05-20-2018, 07:27 AM   #10
2K4S is 26', GVWR is 25500, front engine, TC1000.
