Old 06-15-2017, 03:38 PM   #1
Coachwork: Huh?
How much pain't to mix
I bought a 26ft mid-size bus that I want to paint on the outside and I want to use heavy equipment paint. the paint color that I want is light blue but so far I have not been able to find that color so I need to mix White with dark blue. I need to know how many gallons to buy cuz I have one shot to mix my color and need to make sure I have enough so I don't run out. for those of you who have painted how many gallons for the exterior did it take and how long was your bus. How many gallons do you recommend I mix?
heeranyi is offline   Reply With Quote
Old 06-15-2017, 04:39 PM   #2
Robin97396's Avatar
About a gallon, unless you're going to put it on really thick.
I have a 26' TC1000. You should have paint left over from your gallon. Are you spraying or rolling it on?
Robin
Nobody's Business
Old 06-15-2017, 04:50 PM   #3
I assume you are going to use acrylic enamel. Actually it is quite cheap and very durable. The next question is what color are you going to paint the top... If it were me, I would probably buy a gallon of each color, as the paint can be put in your paint cabinet and used or mixed with other paints as needed. Acrylic enamel is no big deal to make a batch of the same color if you dont have enough. You can also buy a gallon of clear, and the hardener, and your top wet coats you can add more and more clear and get a very high gloss finish that lasts for years. I did that on a 64 chevy suburban for one of my friends twenty years ago, and the paint still looks new, even tho the thing has always sat at the curb in front of his house...
Old 06-15-2017, 05:48 PM   #4
Coachwork: Huh?
I was planning in rolling.
Old 06-15-2017, 06:16 PM   #5
Robin97396's Avatar
Me too. I bought a gallon of rustoleum and two quarts of Flood Penetrol. The penetrol is to be mixed with the paint at approximately 15% by volume, but that might be specifically for sprayers to gain a certain consistency. The label says it helps the paint spread out smoother.
The penetrol is a solvent that can be mixed with the paint as described and can also be used to wipe down the surface of the bus to remove gums, wax or oil. It's got pretty bad fumes and you'll need good heavy gloves for the wipe down if you choose to use this method.
I've watched a lot of youtube videos on bus painting so I may be getting some of the methods blended. Looks pretty simple. As usual most of the work is in the prep.
I've recently sanded the exterior of my 26' bus, weather permitting. That sure seems like a lot of acreage. Now it's raining again. I had to back up a little bit. I'm almost ready to paint and I hadn't done any seam sealer on the roof at all, so I ordered seam sealer yesterday which should arrive by the 18th. I also ordered some really good quality caulk to re-seal the windows. I plan to pull the windows, clean up the frame, trim paint the frame area, re-caulk and replace the windows.
Every job ties in with ten other jobs making everything go quite slow.
Robin
Nobody's Business
Old 06-16-2017, 03:51 AM   #6
tobeamiss's Avatar
Before you run out and buy a can of white and a can of blue...and then having to buy many more cans of white to fix it, remember that...
1qt =100sqft of coverage.
1...Buy a five gallon bullet.
2...always start with white. You'll probably end up using about a gallon and a qt.
3...You can get a tube of very dark blue tint anywhere...
4...only add a couple of drops at a time mixing it thoroughly each time. Test an area.
5...remember that it dries much darker.
This should help save you money instead of using the trial and error method.
I hope I helped.
oh yes she did!
http://www.skoolie.net/forums/f11/to...-it-16557.html
Old 06-16-2017, 07:57 AM   #7
water boy's Avatar
Year: 1987
Engine: 7.3 IDI
Glad to know because Ill be doing this real soon too.....
water boy is offline   Reply With Quote
Old 06-16-2017, 09:31 AM   #8
Coachwork: Collins
Chassis: E450 Ferd
Engine: 6.0L Diesel
Rated Cap: 20 window lickin Jeffies
My bus is 23 ft over all. I painted from the top of the windows down. Sprayed it with Rustoleum Professional. I did 3 coats, mixed 1.5 gal and ended up using about 5 qts. I mixed 5 parts paint, 2 parts Acetone, and 1/3 part Enamel Hardener. I used Magic brand from Tractor Supply. Valspar makes it too.
The hardener is key; makes your paint job turn out better, as the paint is glossier and signigicantly more durable, and it skins over a WHOLE lot sooner...which means that bugs and dirt have less of a chance to get to it while it's tacky.
Goatherder is offline   Reply With Quote
Old 06-16-2017, 09:48 AM   #9
Coachwork: Huh?
great idea, the tint you are talking about, any particular brand or company? I don't know much about painting and didn't realize you can buy tint to mix the color.
Old 06-16-2017, 09:27 PM   #10
tobeamiss's Avatar
Any craft store will carry it.
oh yes she did!
