Old 11-17-2016, 10:31 AM   #21
Anyone have advice about hiring/cost range for plumbers?
bookbus is offline   Reply With Quote
Old 11-17-2016, 11:05 AM   #22
Originally Posted by Tango View Post
Propane fridges can be seriously problematic. If not leveled before turning on they can have the coils go solid. Then they are toast. Also...there all those RV fires...more often than not associated with propane fridges. Personally, I would not have one even if it was free.
Tango & I have a little different view on this one. While propane fridges do definitely have their down sides I think the leveling thing is WAY overstated and the fire danger is minimal.
I live full time with a propane fridge and have for a total of almost 10 years. I spend almost 7 years on the road and got to know a ton of other full timers. While I am sure that there must be some instances of fires caused by failing fridges I have never heard a firsthand or even second hand report.
I have run propane fridges while parked at an angle steep enough that I could not sleep in the bed comfortably. No problem.
That all said: When the propane/electric (2way) fridge in my other RV failed I replaced it with a home type electric. I removed a 6.8 cu.ft. and replaced it with a 10.7 cu.ft with only minor cabinet mods. The new unit consumes less than 1/3 of the power that the 2way did while on electricity. I did also add 2 golf cart batteries and an inverter to keep things cold while traveling.
When the day comes that the fridge in my full time rig I will be replacing it with a similar home type unit.
Old 11-17-2016, 04:37 PM   #23
Refrigerator-Fires
Dometic & Norcold Refrigerator Fires/Explosions - RV Action Items - Escapees Discussion Forum
https://www.hbsslaw.com/cases/dometi...ions-and-fires
Fire Last Night-Warning About RV Refrigerators | The DIS Disney Discussion Forums - DISboards.com
Old 11-17-2016, 05:57 PM   #24
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
I was reading through the complaint filed in the lawsuit filed against Dometic over this and I saw in there that they acquired Atwood which also makes RV type refrigerators.... the main difference between the Atwood models and the Dometic models is the cooling tonic used.... rather than hydrogen (explosive), ammonia (corrosive) and sodium chromate (a carcinogen), the Atwood models used a mix of helium-3 and helium-4 (both inert, nonflammable gases).
This is the one I would look for if you absolutely MUST have a 2 or 3 way refrigerator.... but since Dometic took them over some years ago they may or may not still be manufactured.
Worst case in the event of this failing is that you'll talk funny for a few minutes.
Old 02-17-2017, 08:13 PM   #25
diy or craigslist, but you can do it. don't be scared,get the crimper
Evolutionmoonbus is offline   Reply With Quote
Old 02-24-2017, 09:49 PM   #26
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Originally Posted by AlleyCat67 View Post
Or.... fabricate something like this for a temperature control:
Temperature Control For Freezer or Refrigerator
an inkbird temp controller has all that set up already for under $30.00
its simple ti wire and works. I use one on a fridge at home for a fermentation chamber.
https://www.amazon.com/Inkbird-Tempe...emp+controller
Old 05-05-2017, 07:00 AM   #27
DreamWeaverBus's Avatar
Engine: Cummins 5.9 Allison AT545
Rated Cap: 71
Came here for plumbing, got refrigerators... lol
DreamWeaverBus is offline   Reply With Quote
Old 05-05-2017, 07:58 AM   #28
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Life is like a box of chocolates..
Old 05-05-2017, 08:25 AM   #29
Rated Cap: 71
Heh... true...
Old 05-05-2017, 09:27 AM   #30
Robin97396's Avatar
Does your fridge have an icemaker?
Robin
Nobody's Business
advice, cost, newbie, plumbing
