Old 04-01-2007, 12:39 AM   #1
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
How noisy is your bus when you frame with wood.
I am not looking for a Rolls Royce, but creaks, rattles, squeeks that can be avoided drive me nuts. When I picked up the bus, the clock rattled. I fixed that (temporarily) with a gum wrapper. All the crap that was in the bus made lots of noise. I only made it home because I told myself this was not permanent. I talk to myself sometimes, OK, I talk to myself all the time. Happy now. So how much noise comes from the walls, counters, etc. that are made with wood? Has anyone used aluminum?
I'm hungry!
You Gotta Let Me Fly
Old 04-01-2007, 01:04 AM   #2
KC10Chief's Avatar
Rated Cap: 60
I've thought about the same thing. I've been going through my bus and eliminating all of the rattles. It's mainly the windows and the emergency windows in particular. When I start building, I'm going to bu using a lot of liquid nails and wood glue. I LOATHE squeaks and rattles. I'd imagine that aluminum would make more noise than wood. Use lots of glue, nails and sealant and you should be able to keep the noise to a tolerable level.
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
https://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 04-01-2007, 02:26 AM   #3
the_experience03's Avatar
I agree. The noise in my bus is not from the stuff I did, but rather from the factory stuff. Those bodies flex a lot by design and you're going to hear it. Liquid Nails is like magic, but your best bet is going to be to build stuff so it can easily move the little bits that it needs to silently if you want it to be quiet. Being less dense and rigid that aluminum means that wood should be quieter. It has insulating properties. Many speaker cones, on the other hand, are made from aluminum because it transmits sound waves so well. Just some food for thought.
Old 04-01-2007, 08:30 AM   #4
Moderator
crazycal's Avatar
So if I hook up speaker wires to aluminum framing, I'll have one big speaker?
I have never ridden in a converted school bus before. I just thought all that wood would make lots of noise.
I'm hungry!
Old 04-01-2007, 10:47 AM   #5
lapeer20m's Avatar
i'm opposed to carpet in my skoolie....but i do have to admit that putting carpet and pad in my first bus made things way way quieter!
Old 04-01-2007, 11:09 AM   #6
Steve's Avatar
I am certain that all of the wood in my bus makes it quieter and probably stiffens all the long factory metal. I have a few things that squeek when driving but the vast majority of the noise come from the engine, windows, and wind noise.
Old 04-01-2007, 08:26 PM   #7
GoneCamping's Avatar
Turn up the radio!!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 04-01-2007, 10:02 PM   #8
oldog12's Avatar
... WHAAAT ??? I CAN"T HEAR YOU.... I'VE GOT THE RADIO TOO LOUD ...
oldog12 is offline   Reply With Quote
Old 04-02-2007, 01:54 PM   #9
Engine: 7.3 diesel
My little bus isn't too noisy at all and most of my metal panels are still visable and my floor is still only plywood. But I also drive a school bus about once every other week on saturday or sunday for different school trips or church groups so maybe I am just used to the sound inside the bus.
Old 04-02-2007, 02:00 PM   #10
Steve's Avatar
Its not as noticable until your passengers decide they would like to watch a DVD on the tv and end up having to turn the volume up all the way just to hear the movie over the engine and road noise.
Old 04-02-2007, 07:15 PM   #11
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
I found when framing to make sure the wood studs did not touch the ceiling causes far less (if any) squeaks. I learned this after going all the way up on the first conversion. It drove me crazy with all the squeaking coming from where the walls met the roof . And throwing down a few rubber backed small carpet peices help with driving noise, and the dogs appreciate it also.
-Richard
captainkf is offline   Reply With Quote
Old 04-02-2007, 07:22 PM   #12
Engine: 7.3 diesel
Thats a good point steve. Now that I think about I don't even turn on the am/fm radio's while driving a school bus or any bus for that matter. I often do the ear clip on the right ear in a bus for tunes. I did look up the law by the way and it is legal to do that in one ear only.
Old 04-06-2007, 10:23 AM   #13
oakspring's Avatar
Year: 1985
Chassis: International S1800
Engine: 9.0L Diesel
Rated Cap: 54
My plan is to place a thin rubber gasket material between the wood and the metal when I screw down the headers and footers to my walls. This should give me some flexibility between the two stiff layers: Metal & Wood.
oakspring is offline   Reply With Quote
Old 04-06-2007, 01:30 PM   #14
That's not a bad idea. I've done a similar thing on just about every vehicle I've owned. Plastic dashboard material just doesn't deal well with drastic changes in temperature and humidity and it starts to squeak which drives me nuts. My solution? Disassemble the dash and put those little felt self stick circles between every panel. You'd think they would do it from the factory....I think your idea to use rubber should work equally well since you're dealing with parts on a much grander scale.
3126 in frame overhaul rhickman Caterpillar Drivetrain 18 03-05-2016 05:28 PM
Noisy question dmdqlett Conversion General Discussions 1 12-28-2011 08:50 PM
Noisy engine under the floor browncrown Conversion General Discussions 0 06-26-2011 02:47 PM
Bow / Frame Member Attachment oldog12 Conversion General Discussions 0 08-08-2008 01:27 AM
Frame width the_experience03 Conversion General Discussions 1 04-14-2006 07:31 PM
