05-02-2016, 09:53 AM
How not to plumb
This is a pic from someone who used to post here but has since moved on. I post this for constructive reasons. This person listens to no one when offered advice or even when they would ask for help.
This is what you wind up with.
Under the bus is a plastic barrel and the waste line enters the barrel at the bottom...And there's no obvious vent.
We know how well that will work....I hope!
Don, Mary and Spooky the cat.
05-02-2016, 10:13 AM
interesting to say the least
05-02-2016, 10:50 AM
Chassis: Blue Bird
Engine: ISC 8.3
Well....... constructively speaking: the vinyl tube section could provide good vibration resistance. And it does have a P trap of sorts.
Entering the waste tank at the bottom isn't inherently bad I suppose. Probably the biggest drawbacks to the approach shown are that there's no vent above the P trap level, so water flowing down the pipe will siphon the contents out of the trap and render it ineffective. Also there's the obvious problem of needing a way to vent air out of the tank as water flows in. While the 3/4" PVC and 1/2" vinyl tube certainly can carry water, the drain rate should be expected to be slow.
Maybe backups at the sink are a way of compelling water consumers to moderate their usage..?
05-02-2016, 10:58 AM
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Oh it will work wonderfully once the bus fills up with grey water! insta-pool!
05-02-2016, 11:10 AM
I'm not understanding why they built their own P-trap from numerous fittings, and secondly why it would be necessary to visually see the waste water flowing. I don't like to see the hair clogs.
05-02-2016, 11:31 AM
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
should have put the sink underneath and the holding tank on top with a pump installed...............
05-02-2016, 11:36 AM
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Oh ya, I remember that guy.. You can't fix stupid.
05-02-2016, 11:43 AM
Coachwork: Ward
Dear Sir,
I expect reimbursement for 1 laptop, 1 dock, 1 24" lcd, 1 keyboard from spitting monster all over them after reading your post.
You know that cr@p is gonna eat through the plastic in no time.
...and an apologie to my coworkers for unwarranted showers (eeewwww....!)
05-02-2016, 11:45 AM
Originally Posted by skoolie_n00bie
Dear Sir,
Can I just reimburse the Monster, and you put an insurance claim against the rest????
05-02-2016, 11:49 AM
Coachwork: Crown / Pusher
Ok this was built as a joke right??
05-02-2016, 11:58 AM
No...This person takes everything it builds very seriously.
05-02-2016, 12:43 PM
dam!, he sure needs to put some hose clamps on that vinyl. cant slip anything past this crowd.
05-02-2016, 02:40 PM
I'm agoin to do that with a tolet.
05-02-2016, 03:26 PM
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
LOL, this isn't far off from what I did haha. Due to the way my tanks are mounted, the water drains into the tanks at the bottom, cause there wasn't room for the pipes to enter at the top. I used flexible pool vacuum hose for part of the drain with a waterless P trap, but not reduced to that stupid tiny size haha. As a result of the water draining at the bottom of the tank, I had to put in an extra set of vents in the plumbing for it to flow correctly. Definitely not the best design, but it DOES work. Just not the way its done here.
05-02-2016, 04:28 PM
Rated Cap: 19
Well, it WILL work but the cobbled up trap will freeze and split come winter and it will be interesting to see what those chains do to his grey tank. Worst part is that it would have been cheaper to do it right. This guy has all kinds of goofy ideas, one of which is to build a "battery bank" out of rechargeable AA cells and charge it with a 5 watt solar panel. Another is to use the sink as a urinal. And the biggest irony of all is he calls the previous owners "hillbillies."
05-02-2016, 04:29 PM
Originally Posted by roach711
Well, it WILL work but the cobbled up trap will freeze and split come winter and it will be interesting to see what those chains do to his grey tank. This guy has all kinds of goofy ideas, one of which is to build a "battery bank" out of rechargeable AA cells and charge it with a 5 watt solar panel. Another is to use the sink as a urinal. And the biggest irony of all is he calls the previous owners "hillbillies."
You should link this thread. haha
05-02-2016, 04:33 PM
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Damn, I lost his website name... look at all the fun I missed.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
05-02-2016, 04:36 PM
I'll tell you right now, even hillbillies know people that they consider to be hillbillys. Can you imagine?
Ma, looks lik dey puts the outhouse in da truck. Wonder who dug dat ho?
05-02-2016, 04:39 PM
Rated Cap: 19
Here's the link:
My Portable Home
05-02-2016, 04:40 PM
I like the nonsexual generic identification.
I still can't figure out why this "it" needed a visual pipe in his drain.
That Rain-or-Shine glue definitely comes apart in frozen weather. Use primer and glue.
