Old 10-20-2015, 12:36 PM   #21
opus's Avatar
Chassis: All-American R/E
Originally Posted by Brie View Post
The recommendation I got from a local truck driver who works with diesel engines for a living was to start her up at least twice a week and let her run for a half hour after she's been winterized. So is this recommendation wrong?
Thats nothing but a waste of fuel.
Old 10-20-2015, 02:04 PM   #22
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Probably not his truck or fuel. Same douche that will pull in next to you and run his truck all night long when it is 68 degrees.
I'm hungry!
You Gotta Let Me Fly
Old 10-20-2015, 08:13 PM   #23
Engine: 190hp 5.9 Cummins
The mechanic you talked to wants your stuff to break down so he has a job.
Plain and simple.
Old 12-09-2022, 10:46 AM   #24
Coachwork: Navistar International
Chassis: FE 300
Engine: DT 466E 7.6L
Rated Cap: 32000
So drive my bus around every two weeks so the tires don't get a flat spot, I'm not sure how long it takes for that to happen but Im sure its different for every bus. I take it down the road where I can get up to 50+ for about 30 sec to 1 min. The trip is about 15 min total. Do you guys recommend driving it longer or just letting it sit for the next 4 months. Also what's the reason for draining the air tanks?
BZRoamin24 is offline   Reply With Quote
Old 12-09-2022, 11:22 AM   #25
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
For the driving question, I always drive mine on the freeway to get them fully heated up. The goal is to heat the engine enough that any moisture/condensation inside the engine is vaporized.
Moisture is also the reason for draining the air tanks. As your vehicle (or any shop) compressor squishes the air in the cylinder, it heats that air. When it then flows into the cooler lines and tank, that moisture condenses out and eventually the tank will collect water in the bottom of the tank. Left there long enough, it will rust your tanks. Even before that, enough water in the tanks will lead to water getting into your brakes and air springs.
