Old 06-11-2014, 12:56 PM   #1
wmkbailey's Avatar
Engine: 3126
How to build interior walls
I have been search through posts and see many different ways. Thought I would start one just to bring it all in one place. I plan to start my first interior walls this week end and can not decide how to do them.
I have seen using 3/4 plywood. Solid core doors and 2 x 4 framed in walls like a house. But I think that would take up too much space.
Please let me know your ideas, and I expect nat to tell me how to do it right.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 06-11-2014, 01:12 PM   #2
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: How to build interior walls
build it to last,,thats how I did mine,,2x4 not 2x2 or 2x3,,,same with the cabnit frames,,,that is what is worng with store bought RV,s they fall apart in a yr..
keith is offline   Reply With Quote
Old 06-11-2014, 01:20 PM   #3
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I was planning 2x4 construction for the walls. My floorplan already takes that into account, since Visio's default walls are 2x4s anyway. I was also planning to lay the acoustical barrier then start framing the walls before putting down full floor insulation.
Captain Obvious on deviantArt
Old 06-11-2014, 06:56 PM   #4
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
My plan is to use metal framing, seems to me it will be much easier & lighter to work with
Stuart
Old 06-11-2014, 08:07 PM   #5
wmkbailey's Avatar
Engine: 3126
Stuart
I will check into this.
William
Old 06-11-2014, 09:08 PM   #6
I would agree that steel studs would be the way to go in a large roomy bus like yours. However, (don't you just hate that?) You might want to research the engineering behind steel studs. I seem to remember some discussion related to the need to sheet the studs before they would develop their support function. Still, steel studs would be much lighter than wood and for non-beavers like me, much easier to work with than wood.
Old 06-30-2014, 03:04 PM   #7
syke's Avatar
Chassis: All American RE
Metal studs and sheet it. Just sayin' I was able to frame our bus in a matter of weeks and I know nothing about framing.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 06-30-2014, 04:55 PM   #8
roach711's Avatar
Rated Cap: 19
Stud walls are nice as chases for wiring and plumbing (I'd go with steel studs myself) but in some spots your "wall" could be just a single sheet of plywood. The "walls" between our kitchen/dinette area and the bed/shower area are two floor to ceiling closets built like face frame kitchen cabinets. No lost space and much lighter than two double sheeted stud walls.
The ends of bunks lend themselves very well to just slapping on a single sheet. The bunk frame provides the rigidity and the plywood ends provide privacy.
Here are our closets. The divider between the bed and the shower is one sheet of pine plywood with an oak stiffener glued to the end grain to dress it up.
The Roach Motel
floors and walls jjhomeonewheels Conversion General Discussions 12 03-28-2018 04:07 PM
Thin walls? Accordion Conversion General Discussions 2 09-09-2011 11:43 AM
Interior Framing , Walls and Seats RUskoolietailgater Conversion General Discussions 3 07-14-2010 09:16 AM
Leaking Rain Through the Walls M1031 Conversion General Discussions 2 06-14-2010 07:14 AM
Drywall for your walls?? dammitAndy Conversion General Discussions 3 05-10-2005 11:16 PM
