Old 09-26-2019, 05:15 PM   #1
Year: 2009
Coachwork: IC
Engine: International DT466
Rated Cap: 28
How to determine drivetrain from VIN
Hi,
I’ve googled and googled but trying to find out what the drivetrain is on a bus. Trying to determine if it’s a “city” or “mountain” bus but having trouble figuring out. Any help would be appreciated.
Thanks!
Tmy8ster is offline   Reply With Quote
Old 09-26-2019, 05:19 PM   #2
In my experience with buses you will sometimes be able to get engine info from the VIN, but rarely transmission.
Old 09-26-2019, 05:20 PM   #3
The online VIN decoders may tell you what engine you have but not the transmission or rear end gears.
If you call the bus manufacturer with the vin they can look up the build sheet and see how your bus was equipped from the factory.
Old 09-26-2019, 07:09 PM   #4
brokedown's Avatar
If it's a bluebird you can look it up on their vantage portal, vantage.blue-bird.com. it may give you engine and transmission models and/or serial numbers (which can be looked up to determine model).
brokedown is online now   Reply With Quote
