Old 02-05-2018, 09:10 AM   #1
How to make a skoolie look less like a school bus
The first answer to this question - I am looking to get a pusher, I think they are called a type D. Painting goes without saying - gotta nix the school bus orange. Then comes removing the extra lighting and replacing with something legal....after that...what is the easiest thing to make the skoolie look less like a skoolie? I don't know how to make a poll so have included some options here to get your brains moving in this direction:
- tinting windows
- replacing the door with a more "house looking" door
- covering some of the windows
- replacing some of the skin with flat sheetmetal
- chrome rims
Let your imagination fly...
pengyou is offline   Reply With Quote
Old 02-05-2018, 10:09 AM   #2
1- get rid of unnecessary school bus specific stuff. Lights, stop arm and sign, etc.
2- give it a proper paint job with something designed to paint vehicles and not houses. And yeah maybe some chrome wheel covers or alloy wheels.
3- Install RV windows and cover over areas where windows aren't needed. RV door, too.
4- Good Sam sticker.
Roll Your Own Build Thread
Old 02-05-2018, 11:05 AM   #3
Chassis: Saf-T-Liner MVP ER
Diff'rent strokes.
I'm doing everything I can to retain as much "school bus" character as I can
I like the buses heritage.
Steve Bracken
Build Thread
Old 02-05-2018, 11:07 AM   #4
Robin97396's Avatar
A monotone paint job, like mine, only seems to signify that a bus is privately owned. However, I have considered painting SECURITY very large on both sides of the bus, with a tiny SOCIAL just above.
I skipped the alloy wheels even when I found them on auction locally. They do look nice, but they also indicate money and that would make me feel like a target for thieves.
My windows were already tinted dark.
I hate seeing a bus with a house door, especially wood doors. It reminds me of the old hippie buses.
I cover the windows with from the inside with several layers of insulation panels cut to fit. I don't cover the windows from the outside because I can actually change my floorplan inside the bus and blocked windows would make those interior changes useless for viewing out the windows.
- replacing some of the skin with flat sheet metal I'm striking out on this one. My exterior skin is flat except for the rub rails.
It's generally a requirement to remove the school bus specific equipment. I know some people have refused to remove their stop sign. I removed the extra (bugeye) mirrors and took off the eyebrows over the flashers. I even removed the small handles above the windshield. Seriously thinking of covering the large flashers.
I chose not to install RV windows in this bus. I've done it before and don't feel there is any great advantage. It's not an easy replacement, and it still looks like a school bus when you're done.
Got the Good Sam towing policy but don't remember receiving a bumper sticker. No free advertising here.
Honestly, a bus is always going to look like a bus. People spend a lot of time and effort trying to make their buses look like something else. Why start with a bus if you want it to look like an RV?
Robin
Nobody's Business
Old 02-05-2018, 11:31 AM   #5
Have to totally disagree regarding RV windows vs Skoolie windows. I have never, ever seen a Skoolie window that did not..A. Leak...B. Heat up the inside...C. Help freeze the inside.
Double pane RV windows (especially with a reasonable tint) will eliminate all of the above.
My 2 cents.
Old 02-05-2018, 12:13 PM   #6
Robin97396's Avatar
Fair enough, but I have 17 windows that don't leak now. There were some seaping leaks and I'd have to think it came from the factory that way. I'd imagine you seal an RV window the same as a bus window to prevent them from leaking too, with my point being an improperly sealed RV window is going to leak too.
The severe part of our winter is pretty short. I like having all my windows available when I'm sitting out in the boondocks somewhere. Insulating the windows with panels makes all the difference during the couple cold months.
The insulative qualities of RV windows would certainly be welcomed by anyone. There's no way I can replace my bus windows with RV windows and still have the same views.
I'm not building a show bus. I want to go unnoticed if that's possible. As always it comes down to what your plans are for your bus. However, I reserve the right to completely change my mind in the future. That would be the next bus when I get to correct all the mistakes I made on this bus.
Robin
Nobody's Business
Old 02-05-2018, 12:23 PM   #7
I’m deleting all but four of my side windows and all the rear except for the upper emergency door and putting a rv door off a class a that I’m parting out.
Not doing it to make it look less like a bus but I guess it won’t be confused with a school bus. I plan to replace the four windows I’m keeping with dual pane rv windows as $ allows. I’m putting the rv door on because I don’t like bus doors just a hair more than I don’t like rv doors.
RRRVBUS is offline   Reply With Quote
Old 02-05-2018, 01:23 PM   #8
Robin97396's Avatar
I have to agree on a higher quality door. Not only for the the weather, but also for security purposes.
These bus doors leak wind like a seive during the winters. The alternative to going your direction is removing the bus door and welding them together into one solid door that can then be leak proofed like any normal door. That's for those that are trying to retain the bus look.
I'm about functional utility rather than aesthetics.
I'veI got to admit, I'm impressed with the quality of work done on you guy's fancy buses.
Robin
Nobody's Business
Old 02-05-2018, 05:27 PM   #9
Rivetboy's Avatar
I started with a bus because my goal is to transform into a Coach.
Not a souless RV.
Rivetboy is offline   Reply With Quote
Old 02-05-2018, 05:42 PM   #10
Not a souless RV.
So you're going to have a bunch of coach seats and not do a converion??
Or are you saying you want to make your bus like a converted coach?
Because converted coaches are mostly built with the same "soul-less" components as an RV. They usually even come with the same cheezy vinyl graphics.
