Old 07-11-2014, 12:33 AM   #1
How to remove rear windows - Bluebird
I need to remove the rear windows on my bus (in the back door) without breaking them! Can anyone offer any tips, advice, or tutorials on how to do so? The bus is a 1992 Bluebird TC2000. Thanks in advance!
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 07-11-2014, 12:23 PM   #2
Chassis: B3800 Short bus
Re: How to remove rear windows - Bluebird
Push hard on a corner while trying to pry up the rubber seal around that area. Once you get a corner out the rest will remove with little effort. Let me just say that getting them out is the easy part. Just wait until it's time to put them back in Now that's a pain in the arse!
Old 07-11-2014, 12:26 PM   #3
Is there any way to avoid this arduous task? Take any other route if you can. I removed and reinserted my rear windows to fix some rust and I dread the thought of ever having to do it again...
Old 07-14-2014, 06:04 AM   #4
I'm not TOO worried about putting them back in. I am actually attempting to replace them with an unbreakable, solid panel that I will be cutting from sheets of Duraplate I have. It's the material used on the side of semi trailers made here in the Midwest. A center sheet of composite material sandwiched between two thin layers of painted galvanized steel. Been watching a few videos on reinstallation. Did you reinstall using the methods with a string/rope?
WVO Powered!
Old 07-14-2014, 06:06 AM   #5
I want to take one window out first and cut a replacement to test.
WVO Powered!
Old 07-14-2014, 08:40 AM   #6
Yep, did the rope trick. Still took two people and a good deal of pushing and shoving. It worked out in the end.
Old 08-23-2014, 10:03 AM   #7
crazycal's Avatar
This is a family friendly forum. There is no need to bring sexual habits into his.
I'm hungry!
You Gotta Let Me Fly
Old 07-26-2016, 02:41 PM   #8
GreyCoyote's Avatar
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
This thread may have just saved my butt. (Quiet, Cal! Hehehe)
I could NOT figure out how to get the rears off (Cal!!!) and now there is hope!
(Still giggling from the thread drift tho)
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
GreyCoyote is offline   Reply With Quote
Remove or Not to Remove - Rubber Floor... usmcbay Conversion General Discussions 29 01-14-2017 05:44 PM
Re-installing windows in Bluebird ron_erickson Conversion Tutorials and How-to's 5 05-09-2011 01:27 PM
FREE BLUEBIRD BUS SEATS GREAT SHAPE HELP REMOVE IN PA 16323 bluebird flatnose Classifieds | Buy, Sell, Swap 4 01-04-2011 07:07 AM
How do we remove the windows? gbstewart Conversion General Discussions 4 06-03-2010 08:11 AM
How do I remove the windows from the front door of my bus? dogfinn Conversion General Discussions 18 05-26-2010 01:26 PM
