Old 02-12-2010, 07:37 PM   #1
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Re: Hybrid Theory: Need electrician help
Sorry in advance for not contributing an answer to your question. I just wanted to say that the whole hybrid electricity idea is f-ing incredible. Even cooler is that, if I understand history correctly, it was the Germans that started the idea rolling when they were designing ways in which to power there subs (u-boats back then). I really wish people would contribute the $ and effort to perfect such methods of producing power. Imagine the possibilities!... like you said, 30 m.p.g.(or better) for a 10+ ton vehicle. I know it's possible, too, but big oil won't be happy, and will try everything to prevent it (unless they're the only ones to profit from it). Good luck man, and when you get it figured out, I know you'll not be greedy, and will share the process with your fellow skoolies (wink,wink,nod)
bus-ted is offline   Reply With Quote
Old 02-13-2010, 01:08 AM   #2
the_experience03's Avatar
Series hybrid vehicles are nothing new and have some real benefits over parallel, but also some significant draw backs. I'll post more tomorrow when my ears aren't ringing from a Trampled by Turtles concert. There are at least two senior design projects in my school program involving hybrids right now.
Old 02-16-2010, 09:40 AM   #3
lapeer20m's Avatar
Originally Posted by mightybus
Lithium batterys are the key, because they don't have a memory.
lithium ion batteries have the disadvantage of realatively short life spans....and their life span begins when the battery is manufactured. It is possible to buy a new in box li ion battery that is near the end of it's life span. They do have good energy density for their weight....much better than led acid batteries.
battery "memory" is an urban legend.
Nimh batteries are my favorite. They are very similar to batteries used by edison for his electric vehicles around 1900. some "new" technologies aren't really all that new.
Old 02-17-2010, 07:05 AM   #4
lapeer20m's Avatar
isn't a hybrid a hybrid because it can be powered by both an electric motor and the internal combustion engine(ICE) at the same time?
I don't want to rain on your parade......but you can't power a bus at speed with a 15 hp engine! Not for any length of time at least. In my experience, it takes at least a 150hp diesel engine to power a bus over 55 mph. You cannot do the same amount of work with 1/10th of that hp available.
From an efficiency standpoint, i think physics will make it impossible to transform energy from an internal combustion engine that runs at a constant speed, into a generator, that charges batteries and powers the electric drive motor(s) and to have this setup be more efficient than the same internal combustion engine set up in it's traditional role directly driving the wheels through gears.
every time you transfer energy from one form to another you have a loss. Anytime you charge batteries you have a big loss. A gasoline engine is only about 30% efficient to begin with.
There is a reason that trains use this setup. An electric motor will deliver nearly 100% of it's torque regardless of rpm. If an ICE was used to power the wheels directly, the acceleration would not be smooth, and you would need shift gears dozens of times.
Ice breaker ships also use this setup. Not for it's efficiency, but because if the propeller hits a large piece of ice causing the prop/shaft to slow or stop all together for a split second and that prop shaft was coupled directly to the diesel engine damage to the engine would/may occurr. Having the prop shaft connected to a giant electric motor is good, because when the prop hits a piece of ice no damage is done to the electric motor when it's speed is drastically altered or nearly stopped momentarily.
Old 02-17-2010, 04:24 PM   #5
lapeer20m's Avatar
I like thinking outside of the box, but with the details you have provided it cannot work.
You are trying to get more energy out than you put into the equation.
lets do some math.....
150 hp = 111.85 kw according to http://www.onlineconversion.com/power.htm
take this Honda generator as an example:
it is rated for 5 kw and uses 6.6 gallons of fuel over 8.3 hrs. @ rated load which =0.79 gallons/hr
5kwh = 0.79 gallons of gasoline
111.85 kwh = 17.63 gallons
Even if we stopped at this point, and did not include any losses from charging batteries, and the heat generated by powering the electric drive motors, your fuel consumption would be 17.63 gallons to travel 55 miles which equals:
3.11 mpg.
If you continued and included the rest of the electric system you would probably cut your 3.11 mpg nearly half due to the losses involved in battery charging/discharging and heat loss in the electric motors. Even if you use a more efficient generator/engine you would still would not be able to improve the efficiency by the 10x or 20x required to get 31 miles per gallon.
Old 02-22-2010, 10:18 PM   #6
(Redbear takes short break from Olympics)
Riktor is on the right track, though 30 mpg may not be in reach. An internal combustion engine has to be sized for the maximum instantaneous horsepower needed for acceleration or hill climbing. The size choices range usually from efficient but slow to powerful but thirsty. Is anyone else old enough to remember the original 36 hp VW beetles of the '50's? Interstate driving was foot to the floor at all times. They went past you at 78 mph downhill, and you passed them when they went 47 mph up the next hill.
First step in efficiency is settling on the vehicle's aerodynamics and weight, which determine the power demands. Then the on-board generator is 'right-sized' to provide all power for level highway cruise plus battery charging plus offsetting efficiency losses. The battery bank is used for acceleration and climbing short hills that require more power than the on-board engine can provide. The concept is that by downsizing the engine below maximum demand, storing some excess power during average cruise, and running the power plant at its maximum efficiency, some savings will be realized.
The whole idea is to even out the peaks and valleys of the power demand, averaging the demand toward a constant draw.
Some RV inverter-chargers have a similar feature for providing AC power inside the rigs. If you tell it in programming that you have a 20 or 30 amp shoreline, and it will reduce charging to a stop as the load approaches the 20 or 30 amps, and will add some power from the inverter if the load reaches 35 or 40 amps. The draw on the shoreline is constant, and never more than its capacity.
The electrical grid, at least on the right coast, also averages power to its loads this way, using "pumped storage." Instead of building more power plants to handle the peak demand, you build a pair of reservoirs holding 4 to 5 billion gallons, one on top of a mountain, and one on the bottom. The actual power plants run at a more or less constant output. When grid demand is low, you convert the excess electricity to mechanical energy by pumping water up the mountain. When demand exceeds supply, you stop the pumps, open valves, and run water back down through turbines. This puts the "stored electricity" back into the grid.
It is a lot easier to just put an over-sized engine in and throw more fuel at it than to "right-size" an engine to match the average power to be demanded. There is extra cost in providing any other means of storing power for peak demand. Extra cost equals less profit per unit plus lost market share.
An interesting quote I heard:
A pessimist says the glass is half empty.
An optimist says the glass is half full.
An engineer says we have twice as much glass than is necessary to efficiently support the liquid.
p.s. Battery memory is not urban legend, but is only a problem with nickel-cadmium cells. That's why nickel-metal hydrides are replacing them. And Lithium Ion cells are reported to get about 300 full charge cycles, plus they require intelligent charging. This compares to about 1000 cycles for NiMh, which can use cruder forms of current-limited or temperature-limited charging as well. But Lithium Ions are so much superior in size and weight per unit of power that it is worth it where those concerns factor in. And we all know how heavy the various lead-acid types are.
Old 02-24-2010, 02:33 PM   #7
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Damn nice work. Air bearings- that's intriguing. That, combined with magnet power plays in to a dream/idea of mine leading to something of an attempt at perpetual motion. Fascinating. Keep up the work. H.E. for all skoolies!
Old 02-25-2010, 10:24 AM   #8
2010 hybred busses are available from International/Navistar, I haven't looked into the technical side of the hardware but it fits into the inter city route application that makes sense for electric vehicles with auxillary power override.
Old 02-25-2010, 04:44 PM   #9
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Whatever John... you can laugh and mock, and all of that, but I simply stated what it was- a dream, an idea. If people like yourself continue to mock and throw ashes on people's ideas, then I hope you don't expect to reap any benefits from the ones that become successful. Just an assumption on my part, but I imagine you to be pretty cozy there in your Ca. dwelling , sucking up a lot of the modern conveniences that doubtful you had to break much of a sweat to produce/receive. To be honest, remarks like the one you just made make me laugh at the absurdity of my fellow humans (myself included). I mean, I can tell by your words elsewhere that you're halfway intelligent, but then you go and try and knock me for my science fiction-esque visions. While we're at it, tell me- what part of aiming for such a process as attempting to get close to perpetual motion, ie. frictionless, is too "out there" for your brain to comprehend. I simply was marveling at the air bearings and their application, and embellishing it w/ my own input. Didn't your mommy tell you about not having anything nice to say...
or are you Remus?
Old 02-25-2010, 06:26 PM   #10
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
http://www.newwayairbearings.com/
I thought I'd put this out there for anyone interested, because the whole concept is just plain cool. Also I like their opening statement about their product- something along the lines of achieving what many have dared, despite the limits put on thinking "outside the norm" by tradition and such, you know- stick to the way it's always been done, because it works, and it's the way we've always done it. Rubbish!
I'll bet John can explain all of the mysteries of the world, while knocking blokes like me, all in one sweep of his wrist.
Tell me John- how were the pyramids made? Or are they just nonsense? Figments of my deranged and out/not of this world imagination? Cheers!
Old 02-25-2010, 07:01 PM   #11
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Originally Posted by Iceni John
My dreams are solidly based on practical realities that hopefully I can realize. For example, I dream of converting my bus into a livable and functional motor home, and all that such a project entails. At the moment I am dreaming about how the heck to get an auxilliary electric air compressor hooked up to my bus's accessories air system! Are my dreams grandiose or wild? Heck no, I learned long ago to not waste my time and effort on what is unobtainable, or at least what is unlikely to bear fruit. I don't mean to rain on your parade, but to simply point out that many others have attempted to seek the holy grail of PM, and none have succeeded (for reasons we need not get into here).
If you can do this, good for you (and the rest of humanity). Let us know when you succeed.
John, firmly planted on terra firma
http://gltrs.grc.nasa.gov/cgi-bin/GL...wse.pl?2002/TM
Another tidbit of fodder for the active minds. Wow John, you sound like a very serious dude. ALL of your dreams are based (solidly, no less) on practical realities? Jeez, you're some sort of biological anomaly. Would you consider volunteering for a clinical study we're conducting here at the University? Haha- just giving you a ration! Yes, you stay back there in your realm of safety and "sanity", and leave the grandiose dreams to others more willing and qualified. As far as raining on my parade goes, well, I don't quite believe you when you say you didn't mean to, because you did mean to, and in your most recent reply you still give subtle attempts at just that with your "waste my time... on what is unobtainable" , and even "firmly planted on Terra Firma" I hope you manage to sneak in a totally wild and carefree dream in between your "back to the salt mine" dreams, otherwise your heart will likely grow hard and bitter, and you'll spend your time knocking those who dare to dream...Space Cadet Ted, signing off
Old 02-25-2010, 07:07 PM   #12
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
http://gltrs.grc.nasa.gov/cgi-bin/GL...02-211159.html
Sorry, here's the link.
Old 02-25-2010, 07:49 PM   #13
*Hijack*
A few statements for amusement...
10) In Kentucky, Baaa! Means No! Protect Our Livestock!!!
9) If the world didn't suck, we'd all fall off.
We have enough youth. How about a fountain of SMART?!
7) You know you're an engineer if you have no life & can prove it mathematically.
6) I'm ashamed of what I did for a Klondike Bar…
5) We're Adults! When did that happen, and how do we make it stop!?!
4) If at first you don't succeed, then maybe skydiving just isn't for you.
3) I'm not deaf, I'm ignoring you.
2) Those who say it cannot be done shouldn't interrupt the people doing it.
1) ...And so I Pray...Dear God, Please forgive me for being a smartass with a sense of humor!!!
You cant spell Slaughter without Laughter... Soja ^.^?
*/Hijack*
Old 02-25-2010, 09:31 PM   #14
So I haven't weighed in as promised...I truthfully kind of forgot about this thread...but I will point out that commercially available hybrid buses are parallel electrics, as are all other commercially available hybrids. There is a BIG difference between that an a series hybrid.
*edit* I stand corrected. Those buses to look like they are series hybrids. Series hybrids are, however, illogical for widespread use and really can only be more efficient in a small niche market. i don't think buses are one of them. A parallel hybrid could be. There is nothing fundamentally fuel saving about a bus that uses a diesel engine to charge batteries that then release their current to drive traction motors. The ONLY way that design is energy saving is if the prime mover is meticulously designed to run at a very high peak efficiency all the time. The problem is that electrical loads on the system vary greatly and will likely fall outside the capabilities of such a prime mover.
Old 02-25-2010, 11:37 PM   #15
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Well, I apologize for having a hand in turning any of this into personal debate of a hijacking nature. My intentions were never really to discuss PM, anyhow. I just gave a brief nod to the idea, and it was more about the air bearings on the bus RiktorD was eyeballing. I don't feel like I hijacked the post by the mention of them, nor the magnetic bearings. Both are being used, and hopefully someday will be incorporated into many of our oil guzzling machines to reduce that dependency. This stuff is happening, and it's fun to talk about and dream about, and mold them into reality. I don't see the need for exclusion of ideas solely on the basis of whether or not they're deemed practical by any one. Anyhow, I've got all the nuts and bolts issues of my own simple life in good order- thus the free time to discuss things both practical AND fanciful. I believe the two points meet often, but then again, it's all in the way we look at it. Converted buses seem to me a good mix of the two. They don't require names, but it's fun to give them to them anyway.
I enjoy seeing people reach for their dreams, and while they might not be dreams I'd call my own, it still feels good to see people dream, dammit. Even if you think someone's dream unattainable- what? you go and dowse their dream with laws and facts explaining how it won't/can't work... that seems downright rude and obnoxious to me, unless they asked for your take. What's the rhyme or reason to that? (dig deep) What's someone's dream hurting you. No one here is forcing their dreams down anyone's throat as far as I can tell. Dreams are powerful, as well as fun. I want to see RiktorD's thoughts materialize. If they don't, so it goes. If they do, then hell yeah. I'll feel like I was a small part of something cool and worthwhile, even if it was really just B.S.ing over the comp.
Old 11-26-2011, 11:17 AM   #16
Coachwork: Huh?
Chassis: Chawha?!
Glad I found this thread, even though it looks like discussion got testy quickly, then just fizzled out.
I'm only interested in the concept of a hybrid-electric bus/RV as a matter of theory. The main reason for that is that I do not own, and am not sure I ever will own, a bus/RV. Why, then, you may ask, my interest in the topic of hybrid-electric buses/RV's? Well, I'm interested because having a bus/RV offers the possibility of living a really frugal lifestyle--provided one lives on their bus/RV, as opposed to just taking vacations in it--and frugal lifestyles interest me. Which brings me to why I do not currently own, and may never own, a bus/RV: I don't own one because I doubt I could live more frugally on such a vehicle than I do in my current living arrangement (I do some work for the apt. building I live in for a rent reduction).
Ok, those caveats out of the way, here's why I've come to this forum with an interest in hybrid-electric buses/RV's: because I want to have a frugal-living back-up plan in case my current rent-reduction scenario ever, due to circumstances beyond my control, ends. Should that ever happen, converting a bus/RV for living purposes would begin to become a really attractive option.
With that said, I can add a further reason why a hybrid-electric system would be a desirable one for my purposes. Should bus/RV life ever be in my future, I would not be looking to be traveling on said vehicle year-round. Rather, I would want it to be parked in one or another spot for as long as possible/feasible, moving the vehicle only when necessary (neighbors too noisy, found a better parking rate elsewhere, etc). That qualification having been made, the hybrid-electric model looks attractive because a very good electricity generating system would not need to be added to the bus/RV, since it would already be built in--it being also the primary means for the vehicle's propulsion.
In any case, as I go on "dreaming" about this possibility, can anyone point me to any further discussions on this forum about hybrid-electric schemes for buses/RV's, or related resources on the web?
Thanks,
James
wayover13 is offline   Reply With Quote
Old 11-27-2011, 12:33 AM   #17
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Costs me a tad over a C note a month to live in my own bus, on my own property, including tags and insurance for the bus, property tax, generator fuel and propane. Live pretty much the same as I did in an apartment in LA, except my bus is larger than my apartment was and costs about 1/12 as much. Doesn't count groceries, of course, that's the same no matter for either case.
I's think that the cost of adding a domestic electrical system to a skoolie is a pittance compared to the cost of buying a hybrid-electric bus - if you can find one - and adapting it's electrical system to domestic use.
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 11-27-2011, 02:50 PM   #18
Coachwork: Huh?
Chassis: Chawha?!
Thanks for your input, wtd. That's some pretty frugal living you're doing there--gives me a good target to aim for. Your property is undoubtedly out in the boonies somewhere?
Yeah, I could never justify the cost of a new--or likely even used--hybrid-electric bus. Nor would I want a production RV with any kind of standard interior. I'd want something I designed myself. So what I had something in mind for the powertrain is more like a home-brew project--kinda like the Opel they set up as a hybrid-electric back in the 70's and wrote about in one of the Mother Earth News issues, only on a larger scale. I recall they used a military surplus jet starter motor in that vehicle--a motor that would, of course, be so appropriate in a much larger vehicle like a bus-RV.
James
Old 11-27-2011, 03:45 PM   #19
Coachwork: Huh?
Chassis: Chawha?!
James
Bus / Van hybrid Kype Conversion General Discussions 2 11-10-2014 10:25 AM
invertor theory 101 teach the new kid in cool skool delbertinie Conversion Tutorials and How-to's 14 03-09-2011 01:57 PM
Follow the Data, Forget Conspiracy Theory bus-ted Everything Else | General Skoolie Discussions 0 06-07-2010 09:31 AM
do-it-yourself electric hybrid idea icnivad Electrical, Charging and Solar 7 09-10-2009 06:54 PM
Hybrid school bus introduced SeanF Everything Else | General Skoolie Discussions 0 12-17-2006 12:06 PM
